jimbiss
Those links are SWEET "thumbsup""thumbsup"
Like These?:lol::lol:
Them are SEXY! Are they gonna be something on the CDW product line?
Are you not afraid of the square corners next to the ball ends snagging? Or are they closer to the same size than they look in the pics.
Good to hear."thumbsup"Nope, im not worried about it at all, The corners are not sticking out that much. If anyway it ends up being a problem ill file the corners.
.... And these are the only Traxxas rod ends I could find that fit the losi spring cup. They are the 4 that come in the #1942 rod end set.
Got the shocks set up to 3.464" long eye to eye. When assembling them use the biggest spacer it comes with.
I thought the big spacer was to go inbetween the 2 o-rings in the shock cap? Mine came with 1 big spacer and 2 littler spacers.
yea, there biggest spacer goes between the o-rings ,but it also come with limiting spacers. There are 2 spacers connected to each other. use the bigger of those 2.
How are your CVDs holding up now?
I blew a pin apart last night and swapped both pins around to 1/16" drill bit shafts. I hope this holds up because Im only running 7 cells and plan to upgrade to 10 cells.
