Harley's XR10 #AX50062
Seems silly that the outer rings were banned in retrospect.
Looks sweet Harley, as usual. "thumbsup"
It's more of a fact that the inner ring idea has been being used forever. We used to stack lead weight inside the wheel to get the same effect. However when allowing BOTH you can effectively make a wheel as large as you want with whatever size sidewall you want. That is why we wrote the rule the way we did.
Night Session
Since the body skin theme is "Urban" I thought this was appropriate.
Awesome!
If you´ll drive that thing have as good as it looks I´m impressed."thumbsup"
pic's look Awesome
Vanquish bling isn't that shabby ether. ;-)
Wow it looks great with those wheels mounted up! Nice pics."thumbsup"
And thanks for the help with the dig options.
No different then it doesn't have a tie rod going from knuckle to knuckle. Which leaves leaves a Gap on one side. Not sure you got what I was talking about. So I photoshoped you this.."thumbsup"
A rock jammed here not only hangs you up, but takes your Steering out as well.
Then don't drive into the rock, put a tire on it :flipoff:
Yes I will be doing a very detailed setup on both setups as well as a stick radio setup.
The 3PMx will not be setup with dual ESC's though. It will be a single ESC and a dig switch.
Actually I guess I'm more looking forward to that 3PM setup anyway since the single ESC/dig setup is what I'll be going with "thumbsup"
Will be interesting to see you're take on the programming for the stick setup too.
I'll get all the info up ASAP. The stick radio programming will be very straight forward, probably nothing new to you.
Your truck looks great,
I wanna know more about that new radio !!
The minute I am allowed to I will have the info up I promise!
New to MOA...so excuse the noob question..
I just purchased the Br00d motors. One is labeled with a R for reverse. What
axle is running in reverse..front or rear...:roll:
