Can someone explain the differances between a FXR and a FXR Pro?
Is it that the FXR Pro will handle a little more power?
FX-r:
Controls: Forward/Brake/Reverse
ON Resistance: 0.0012 Ohms
Input Voltage: 4-9 Cells, 2S Lipo (3S Lipo with 35T or higher motor)
BEC: 6.0V/3.0A
Motor Limit: 13 Turn
Throttle Profiles: 7 choices on board
Reverse Type : 3 choices on board; none, delay, immediate
Reverse Strength: 11 steps on board
Rock Crawler Spec: 3S Lipo compatible when used with 35T or higher motor
Dimensions: 1.1 x 0.80 x 0.40 " (28 x 20 x 10mm)
FX-r Pro:
ON Resistance: 0.0006 Ohms
BEC: 6.0V/3.0A
Motor Limit: None
Reverse Strength : 11 steps on board
Dimensions: 1.1 x 0.80" x .60" (28 x 20 x 15.24mm)
Weight: 0.8oz (24g)
Pro has slightly better specs (no motor limit on 2S), not enough of a difference to me though.
