Szczerba
Hello Shane,
well done at Nats... I'm fan of your driving style. A question though : you're the third guy I see modifying the SA chassis front (Del Monte & Racer_ZH also did), so what this mod brings ?
Ty,
Emmanuel.
Thanks for the complements.
Almighty Malach mentioned I should widen my shocks out at the chassis. With the shocks laided back and the narrow distance at the chassis point shock mounts makes for a quick reacting suspension setup.
Space the shocks out at the chassis and the action is slowed due to the shock angle.
When the truck flexes side to side, one wheel at full flex and one at full droop on the same axle, the fully compressed shock should be close to perpendicular to the axle. So, spacing the shock out at the chassis helps this.
So, in short, try to get the chassis mounting points of the shocks close to the same distance as the axle mount points.
I only had time to space the fronts out between comp runs and it really helped smooth the front flex out.
Of course all trucks are different and drivers like different setups.
Sorry for the long explanation.
