got my 4pk set up by your vid.great info thanks. just have one problem i would like to overdrive the rear at times is there a seting i can change.set the mix at a 100 so i can go up to 120 and it works butt not enough.thank for all your help great job
Sorry, 120 is the max. I can't say I have ever really had people want to overdrive more then 20%. If you need more I would just suggest using a rear burn.
There is an older setup that can be used to drop the front motor down, but I do not suggest this for several reasons. It just adds more complications to the setup and wastes time while on course. If you think you must have this option I will post up the instructions on this old setup.
