SteerAndStuff
Saw a pic of a bomber with wraith length rear control arms. What's the wheelbase length in that configuration vs stock bomber length?
Essentially the bomber makes its longer wheelbase from the longer rear control arms and the skid mounts are essentially the same distance between the 2
You know for $8 you can get an adapter plate from the DMG to run that SS trans on a bomber skid. That includes hardware and you'd save yourself a ton of trouble with all the correct link mounts already there. The problem with using a Wraith skid and trying to run the lower forward trailing arms properly on the outside parallel to the chassis is making it double shear.
Gotta check eBay man. I've already got my second complete bomber chassis and third bomber skid. Got the skids for $10 each shipped from a seller called bizarre hobbies. I got 2 adapter plates from DMG because I'm swapping out the Wraith skid on my Spawn that's running trailing arms to get all the additional link mount options and correct trailing arm placement.
There's 2 on eBay right now. 1 from bizarre hobbies for $10.90 shipped. Lol. I'm just trying to help you out man.
And anotherPics?
Woo hoo, im going to run wraith links and thought thats how I would mount my shocks too but seeing a picture of it confirms it. THANK YOU.
Are those wraith links or...?
