Well, technically, YES cuz my eyes and wrists hurts too!!!
It was good getting to know you and your thoughts behind suspesion setups.
Keep up the good work with the Biz!
~John
Thanks
~John
All of that being said, droop or sprung, nothing means a hill of bean if the link geometry is off. Get the squat/anti-squat right and almost any rig will crawl fairly well.
So in a droop set up you would rather have your suspension move slower (thicker shock oil)? Or do you want a thinner oil, making youe suspention faster?
I like mine to move slower, it makes the suspension more predictible.
Ive been working on a drooper for a couple of months now and here is what i have seen.
Pros
Lower COG
Axles drop down when hung up
Little body roll on sidehills
Great for climbing steep inclines
Cons
Torque twist in the back left
Takes a lot of tuning
Im trying to stay open minded, but i just cant think of many cons. I have been very happy with my suspension setup. It just takes a lot of tuning sense you cant buy shocks setup for droop.
See here is where I just get lost again. You say Pro's.. And list Lower COG. Well you can set up any 4 link Sprung set up to set just has low. You can have the links just as flat. By one either running shorter shocks or changing the angle of them and so on. On the Dropping the axle part. Just sounds goofy to me still. I can see Droop helping on Sidehills. Steep inclines I don't see it being any better then other setups. Speical a Stick set up. Just not possible b/c of the break over point. We need to post some videos showing how this works and why. And what makes it so much better then a Correctly Set up Sprung rig.
Ok, im sorry i wasnt clear enough. For lower cog, i say that because droop makes being a belly dragger easier for me. With a sprung setup being a belly dragger and you get high centered your stuck unless you can rock off. With droop being a belly dragger it lets the axles drop some and try to get traction. The axles dropping might seem funny, but it works real well. To me this is the biggest advantage.
As for it being better in other areas, i guess its personal preference.
No I understand how that would help. But the amount of drop it would need to do any good from getting off from being high centered would also hurt in many other spots aswell as the rear end would try and walk under the chassis.
I found that a 50/50 droop to sprung setup works extremely well for me. I run a .55 inch internal spring under the piston and a Losi 2.75 inch external spring at each corner. At ride hight the shock is at half droop with 2 springs holding it there. I get the advantage of a droop setup with the mechanical traction of a suspended rig.
Ride hight at rest is 2.75 inches with a max belly clearance of 3.20 inches. All of that being said, droop or sprung, nothing means a hill of bean if the link geometry is off. Get the squat/anti-squat right and almost any rig will crawl fairly well.
For the weight being scale, I think you can build a rig to scale weight. Think of a block of Steel 10"x10"x10", then think of the 1/10th scale block that is 1"x1"x1". In terms of volume, the 10" cube will have 1000 times the amount of steel and weigh 1000 times more. Same for a crawler. A 5lb 1/10th scale crawler is 5000lbs scale weight. Totally in line with a real vehicle.
No john is right.Since our scale crawlers are 1/10th scale wouldn't you just divide the real vehicle weight by 10 to come up with the scale weight? That would be 5000lbs/10=500lbs for the crawler. Am I doing that right? Wouldn't 5lbs be 1/100 of 5000lbs? If so, that's why it would be crazy to try and do scale weight... maybe I'm dumbing this all up..:roll:
