guidetti_angelo
thanks Hurley, i will do all that you reccommend me !!
first i have to re- solder the capacitor!
Hey guys, the free RX deal is going on again until the end of July. Buy the 4PK from any elidgable dealer and get a second RX (3 channel version) for free. Remember with the new recommended programming you only use 3 channels on a 2.2 MOA rig 8)
http://www.towerhobbies.com/products/futaba/futk4900.html
Damn, bought mine too early!
yesterday i tested for firt time my berg and i noticed that sometimes front and rear don't go with the same speed
Getting a Berg perfectly setup is some what of an art.
- Check to make sure that you do not have a reverse delay programmed in your ESC's. This sounds like it could cause your "1 second" delay.
- You need to make sure that your gear mesh front and rear are set well. If there is any binding in either axle it can amplify the stall effect.
- You also need to make sure that all of your electronics are soldered well. Bad connections do not flow current as well and will again cause stall.
- Program the throttle position on both ESC's at the same time as well.
- Make sure the timing on both motors is set to zero (mark on end bell and can aligned).
The wheels will most likely move at slightly different speeds if you have the car off the ground but this won't be noticable when driving as long as everything else is set as described. Everything else is going to be in the setup of the car not in the programming of the radio. I would suggest reading on the topic in the berg section for further info. Anything else in regards to the radio just ask here "thumbsup"
Harley! Thanks for posting this up, m'man!! I was literally half way through the checkout process at Tower when I decided to check this thread for something about receiver compatibility. I was able to go back in, change the item number on the radio and got a free RX. Saved me $80 or so by cutting one of the RX's off my order. "thumbsup""thumbsup""thumbsup"
That goes for me too.thanks for heads up..
I call tower and told customer service i bought a 4pk two weeks ago and did not receive 2nd rx. customer service rep said it was a different part# to get that special offer but they would honor the special anyways:mrgreen:
Called Tower today and they are honoring the deal.
Thanks for the heads up guys.
i have rear motor that starts earlier then front one, i suppose for much weight that the front axle has with servo, weight wheels, i put 140 gramms for each vp wheel.how can i tune?From my experience, you will almost always have one axle spinning faster than the other. This is due to many factors, such as:
Very early on I fought the issue you guys are having with motors that spin at different speeds. The first issue I had was that I was using one new FXR and one FXR that was about a year older. I went through all of the calibration procedures (one at a time, two at a time) with no luck. The radio was setup properly and the ESCs were setup identical. I found, only after connecting the motor output from each ESC to an Oscilloscope that the ESCs were outputting different voltages at 100% throttle which explained why the motors were spinning at different speeds. Swapping out the ESCs for two brand new ones and changing nothing else cured that problem.
- ESCs from different production runs
- Motors that aren't in the best shape and/or quality
- Axle machining tolerances
I still have issues with the axles spinning at different speeds, this time it seems that it is the motors. I know it is the motors because if I swap the front from the rear, the lowest speed motor is constant. No matter what kind of motors you have, you will always be fighting different speeds to some degree or another. I will tell you this, if you can't get them to be the same, put the faster motor in the rear.
i noticed that also on lifted tires rear end starts earlier..
thankssss;-)
These are just things that will happen when the wheels are off the ground. It's not something that will be noticed when you are driving. As long as you have everything setup and calibrated like outlined in this thread the car will drive well.
Remember you can dial the mix percentages in to make it feel how you like as well.
good "thumbsup"
i modify epa for second and third channel, second ( front ) at 110 % and third ( rear) at 95 % and pmx2 at 95 %..
i try this set up in my parquet and i noticed a good change, tomorrow i will try it..
what do you think about..
Do not adjust the end points. Leave the setup as detailed in this thread. To get all the proper functions of the mixing you need to have the setup as I have shown.
so you said me to leave set up as shown and to dial mix while i.m running?
I was saying to leave the setup as I have detailed. Do not make the changes to the EPA's and such as you have done.
