4PK Setups, Tips, Tricks and Help
Most motors are set to 0 degs so u can run both directions,That's why Brood sets up motors for front and rear use and sets timing at 6 deg so your not tearing up your com with 0 deg of timing.
Additionally, the brushes seat according to the direction they're run in.
Thanks man though I'm not familiar with the mechanism, but I will try to figure it out.
I looked on page 1 for the 3 position with one esc and it said the way to program is outdated . Tried to view the video and there isn't one.this is too complicated, I emailed futaba maybe they will have an answer.
The 3 position switch part is universal. Such as the winch setup.
Dial menu
Select a DT button
Set value to 100:NOR
i saw the wiring diagram for supers with dual esc, dual servo and 1 bec. if i was going to use goat 3s escs which they both have their own bec's just hook one bec to 1 servo and the other bec to the other servo correct
Hi there Josh Harley?
im about to get another receiver for my old 4PK... will this
Futaba R614FF 2.4Ghz FASST 4-Channel Receiver
works smoothly? I noticed the original R603FS 2.4ghz has only 3channel and that B/C for batt i assumed.
Thanks for any clarification. Thanks :)
Yes that RX will work and is smaller.
The original RX is the 604 actually which is a 4 channel. The 603 will work but is only a 3 channel "thumbsup"
wow:shock:
i think i've been cheated.. this is what i have in my hand right now, the 603... damn:evil: [*i bought 1st hand.. the damn hobbyshop must have swapped or something :x ]
ok then will get the 614 .. i need the 4th channel for my scale truck project. Thanks Josh for the explanation.
wow:shock:
Yes if you got it first hand you indeed did get shafted! The 604 is the RX that comes with the 4PK and the 614 comes with the 4PKS. Raise hell!
I will do just that if the hobbyshop still open.. :evil::evil:
maybe that's why they closed for good now.. cheating others :lmao:
oh well.. this 603 done well so far.. even gone submarine *in the balloon* during my international race here.. end up 2nd *cough *cough :mrgreen:
Anyway ... thanks.. will definitely make sure now with the 614 :mrgreen:
OK I can't figure this out for some reason.
I can only the 2nd Ch to show one ESC. I can get the 2nd and 3rd ch's to show both ESC's...
I pull the Throttle and on the 2nd line (Ch) Shows movement. I turn on the Mix and the 2nd line (Ch) just flashes a little and goes away.
Nothing shows up on the 3rd line (ch)...
