4PK Setups, Tips, Tricks and Help
Yeah but I am wondering what mixes you would use on a 3PK (only 3 channels). Maybe I need to think about it more, I can see it easily on a 4PK.
Crap, didn't see the 3PK part. Lemme see.
Got it, here is the mix that will allow you to use 2 different buttons to control the 3rd channel.
PMIX1
mst:ch3
slv:ch3
ofst:+100
PMIX2
mst:ch3
slv:ch3
ofst:-100
Using the "offset" feature of the mix menu is the key here. It allows the 3rd channel to go full throw in one direction with the push and hold of a button. I assume the 3PK has 2 mixes, right?
Let me know if you need more detail, I can type it up tonight.
Ok did what you said on the mix set up do i need to change any of the buttons for this to work
i set up SW2 and when i press it it will work but dosent go back to neutral it go to rear dig not working the way i wanted can you help
Change the buttons from "ALT" to "NOR". That changes the behavior of the button from a "push on, push off" to a momentary type where you have to hold the button to keep it on.
Did the bbeaty workaround for the 4pks. Rear value is displayed on the right as well as the servo view on the left. Good to go.
Did that it will do what I want front dig rear lock but when i let go it will go to rear dig front lock can't figure it out its got to be in the mixing but how to fix it i don't
Ok i read it again can't get it to work here is the pics you asked for
http://i876.photobucket.com/albums/ab321/jmontes_21/2010-12-07195226.jpg
dang i keep reading and switching stuff around both from jdawg53 and herley0706 posts and well............................................................................. my radio must be really messed up o well guess ill send it in and get the software update and see where it goes from there ..............................................
:afro:
:afro:
What are you try to accomplish? If you are setting up an MOA, just follow the video.
