WheelChair
Winner of the '07 RCC dumbass award!
thats what i thought. do you think i should take the extra weight and run 2 batterys? one to each speed controll?
I have never ran two speed controls off one battery... I could not tell you.
I guess it works for others... If any speed control would handle the stress, it would be the mamba max's...
A spike or drop in current is not good for any electronics. it stresses them.
if the speed control is connected to its own battery, it expects, and is designed to handle the current drop when you pin the throttle.
Add another speed control, dropping current when there is no signal to run the motor is a spike the ESC was not expecting.
The MM has 3 capacitors on the supply, capacitors soften or cushion the voltage spikes. So maybe it does not effect the MM.
I think you will have to talk to someone running something close to your setup. :?::?::?:
I believe if you run two 4400's you will have KILLER run time.
but if others are getting good runtimes with your setup something is up with your rig.
hope it helps!
Peace
