I should delete this thread for all the misinformation............
Clod stall is caused by differing loads on each motor. Each motor recieves a set voltage from the esc for any givin point on the throttle. For example lets say that 1/4 throttle deliveres 2 volts to the motor. This will only produce a set amount of amps, amps=torque. So now you have 2 motors putting out a set amount of torque. While climbing the rear receives more load. If this load exceeds the amount of torque the motor will stall. In a clod the rear will get more load durring a climb, so while the torque supplied by said 2 volts isn't enough to power the more heavily loaded rear it is enough to spin the front. Stall.
So if you just add another esc with a y harness this is what happens, you give the truck 1/4 throttle, the esc's get the same signal, they send 2 volts to the motors. No difference. Waisted ESC.
While driving there is an infinite variable of load between the front and rear. No setup will automaticly adjust for this, only slight compensation can be achieved.
The only cure is to learn to drive a twin stick radio with no mixing. You control both esc's all the time. Thats what I do, it works extremely well for me. It also opens up a whole new world of abilities to the world of compitition.
That is my novel and the last time I will explain it."thumbsup"
