I believe I cut out about 3 lugs worth. Basically I just cut it once then pulled it around a tire until it looked like it would line up well then I cut there, trimmed the lines straight and glued it together with 2-3 second CA. I think it is better to be a little tight then a little loose because you will have better hold to the rim. I also wanted to make sure they were short enough for scale comp use.
