Gotta knock out a few more protos before I settle on the best fit for the 500 size. Then we move on to the 3.5 ounce 400 :twisted:
This is the smaller version on the far right, one of the multiple designs I have for the Puller 500. It is .2ounce less than the heavy version (4.3 ounce total with heavy arm), uses a full size 540 armature, but has a slightly higher speed for the same wind. Detent torque is also higher than a standard 540 with the intended armature, but not by much. I'll have to test a set to see if startup is good enough compared to the big version. As you can see they are quite a bit smaller! That is the tradeoff for going super tiny, startup has to suffer if we want strong drag and torque.
60% magnet coverage
2000kv
2.6a no load @4v
4.3 ounces
28.5mm diameter :shock:
So now I get the fun job of having to choose one design before we make the mold, which means sending some out for testing and putting a pair in some of my rigs. The best part!!
