I have a hv500 from the end of batch 1 ish? HH ran out of their first batch but supershafty had a few left so I grabbed it from them. Could this servo have a issue with the over hardened pin? Thanks.
It's about a 3.5% chance from that batch
With the SHV500....how do you wire it up exactly? Do I wire a jst off the battery plug on my esc?
Anyone have any info yet on an aftermarket or exact fit set of gears for these?
I have one kicking around with busted gears. Not covered by warranty.
Are there instructions somewhere on replacement of pins or gears, or is it obvious once you get inside?
I've employed a group of locals to help beat these things harder and ensure we get lots and lots of abuse. They can't break one yet, even the proto model I assumed was going to overheat is actually performing stellar.
Ran into an odd issue yesterday with my HV500. Thing powers up great and functions fine when under power. However when i disconnect the battery. The servo will only turn in one direction. it's locked up tight. apply power again and it functions like it should.
Wondering what this might be.... any ideas?
I noticed this also with my HV500. With no power i can grab my tires and turn them one way fine, turn the tires back the other way and once it comes close to center it feels gritty and then locks up. Under power there are no issues at all.
