Who made your front bumper??
I imagine he did because I drug my vanquish light bar to the point it flipped backwards. It was a tough course and luckily I slathered my rx8 and the sons brxl in aircraft corrosion x. It was a fun course and harley got a very nice wine glass for his driving. Too bad he didnt get miss missouri though:lmao:Rig ran great today, crossed the line first on stage one. Stage 2 starts in a few hours. Hoping to keep the run going. My only concern is the water and mud effecting ant of the electronics.
Did you smack the light bar? It looks like it's points up into the sky
Sent from my PG86100 using Tapatalk 2
thanks Harley, you gave me alot inspirations and I have a question here actually two, first is you use the dual servo setup, but I dont see the second servo in your pictures, how that is done? I tried to search a bit in the forum about the duel servo steering but no luck and secondly, futaba bls157 is water sealed, does it mean it is waterproofed already out of the box? or still we need to do something to get it waterproofed? thanks in advance.
Hi - I see that Tower has marked the BLS157 as discontinued. Are you aware of a replacement? Looking for something high end. Thanks!
Parts have started to roll in.
First off, from Holmes Hobbies, my new Tekin ROC 412 3100kv motor and Castle Mamba Max Pro ESC.
Harley any chance of getting the castle link setup that your using posted? Or a good baseline to start with?
I have a 9 lb Wraith with similar drive train same motor and ESC.
Sent using Tapatalk HD
Vacationing in the poconos?:lmao:
Working in Chicago...yay. :roll:
Who are you kidding...you don't really work! Your post count should tell you that!:lmao:
I'm out of town for the next couple weeks so I can't upload the file.
My settings are very basic, from memory I believe it's something like this:
High power startup
3v per cell cutoff
Full sensored operation
Straight throttle and brake curves
35% Drag brake
Crawler Reverse
100% reverse strength
I'm sure you have ran this rig to death by now! How has the corrosion x worked for you so far? Have you reapplied more, or still rolling on the original treatment? I'm about to buy some, but wanted your input!"thumbsup"
