Ever since I built my TRX4 Sport kit I have been wanting to fit longer shocks on it in an attempt to get more travel and articulation, while maintaining the stock ride height, COG, and spring rates.
The first link in that chain is the upper shock mounts. There are several mount options out there that allow you to raise the upper shock mount by 10mm relative to the chassis. What this means is you could theoretically run a shock which has a 10mm longer compressed length while maintaining the same ride height and bottom out at the same point but get more travel.
I am not condoning people buy the hot racing shock mounts as the panhard mounts have been known to snap, there are ebay options with double panhard mounts.
The second step is the shocks. I have found two potential options that could work. But first lets talk about the specs on the stock TRX 4 shocks:
Extended Length: 90mm
Compressed Length: 65mm
Travel: 25mm
The first option is the long GTS shocks that come with the Traxxas Long arm lift kit. They are Part # TRA8160 and can be purchase separately from the lift kit:
Extended Length: 110mm
Compressed Length: 75mm
Travel: 35mm
Additional compressed length over stock: 10mm
Additional travel: 10mm or 40%
These actually are pretty perfect as you pick up exactly 10mm in compressed length which is offset by the 10mm taller shock mounts. And they are literally just a longer version of the stock shock so they should fit perfect.
The second option, and what I was going to try because I already own them, is the Hot Racing 120mm TD120RV02. These shocks are dual-rate shocks and for some reason offer a lot of travel for their size:
Extended Length: 120mm
Compressed Length: 77mm(!)
Travel: 43mm
Additional Compressed length: 12mm
Additional Travel: 18mm or 72%(!)
These shocks are not quite as perfect since they are 12mm longer compressed but close enough. The offer huge travel in a relatively small package.
Now for the pictures. I put a new shock mount and the Hot Racing shock on the left side of the rear axle and kept the right side stock. First up is the truck sitting at ride height after cycling the suspension. You can see its sitting level despite the left shock being 30mm longer overall:
Here is the shocks at full compression, again, level because the additional shock tower height compensates for the longer shock:
Here is the rear axle hanging with both shocks at full droop. This is where the difference lies:
Here is the articulation available(we assume the stock shock is a standing for the HR shock since they bottom out at the same point):
Here is stock articulation:
Last but not least, the stock TRX4 springs fit the HR shocks:
This means you could run the springs for the longer TRA8160 shocks on these hot racing shocks which should solve any spring rate issues you might run into.
I know someone is gunna say that travel is bad. What about side-hilling?! What about climbing?! I fail to see how that is an issue. If you run the same ride height and COG while maintaining the same spring rate and bottom out point, how can either of these be affected substantially? Maybe in some odd scenario the extra shock length could allow the tire to push off the ground where the stock shock might have reached full extension causing the tire to leave the ground instead?
I guess I would rather have more droop and flex to allow the tires to stay in contact. Imagine high centering on a rock where the stock shocks are hanging in the air and your tires arnt grabbing. Now imagine you tires can drop 18mm father down and are now touching the ground and have some bite to pull you through.
Worst case is I can experiment and see what happens. I already own the shocks and the towers were cheap. I may but a set of the springs for the longer GTS shocks and put them on my HR shocks and see how that works.
Travel: 25mm
Travel: 35mm
Travel: 43mm
