my battery isn't much longer than 85mm. much longer and you hit the servo. but i have cut the back lip off the tray off to make it fit. and the width on mine is 32mm but i would say the max width would be 40mm. the height would depend on the holes you have you suspension set at. i would 30mm would be max. does that help you at all
Well, I think I have had success :|
Have just returned back with THIS
Dont know if its the right choice but it fits with plenty of room to spare.
The pack you bought passes 7.5 amps, almost enough to power the rx and servo's. You wanna find a pack the passes 40 amps cont and 80 peak IMO, Losi makes a 1650 30/50C thats a perfect fit.
That's a perfect pack"thumbsup", flows a little less amps but thats made up for with higher voltage, also will have 50% more wheelspeed.Not having much luck finding the 1650 but have come across THIS here in the UK
