Go Back   RCCrawler Forums > Scale Rigs General Tech > 1.5 Scale Rigs
Thread: The Hilux Trail Rig
Old 10-13-2012, 12:35 PM   #1
Default The Hilux Trail Rig becomes a Chase Truck
Hi everybody!
I want to introduce my slow 1.55 Hilux project. I just recognised that that I did not post it on here earlier (don't know why) but now I want to catch up on everything.
The story so far......
chassis is a genuine Tamiya Bruiser with all screws turned inside out. So no srewheads are visible outside. I then heat treated the chassis with a gas torch to hot red. After cooling down, I put it into water and let it dry. This gave it the weathered look with all the real rust. The chassis itself is very weak and twist easely when articulating. Therefore I welded some cross members (round and square material) to give the chassis more stiffness.
In the first stage, I hade original vintage Bruiser axles with Rummy conversion on, but I changed to RC4WD Yota axles soon. 1.55 Rock Stompers with Void beadlocks where my first wheel/tire choice. I changed later to Rock Stompers with black steelies. This is my current wheel/tire combo.
Currently I have a RC4WD Disruptor reduction unit and a Killer TC installed. I started to use JunFac Universal shafts, but also changed these soon by much more scale looking Shafts from the bay.
First front bumper was from an Axial Honcho, but I did not really like it. The current bumper is from CZ made by RCmodelex and all steel. The bumper is welded to the chassis to increase more stiffness to the front. Also the Roofrack and the Hardtop is from RCmodelex.
The suspension consist of turned down TLT shocks and a combination of Bruiser and Juggernaut leafs. I opened them and interchanged leafs for best result. They are now higher than stock Bruiser leafs, but weaker than Juggernaut leafs.
Last modifications are a fuel tank, rear steel bumper and rock sliders. The fuel tank is located behind the rear axle which is not absolutely correct but, I do not have space where it should be located because there is the modified Bruiser radio compartment. It will carry special configured 6cell battery. This ensures a low center of gravity because the heavy battery is in the frame and not on the frame.
The rear bumper is made of cut and drilled rectangular steel. Directly welded to the frame. That also add some stiffness to the frame. I was inspired by a real car reference picture I found on the internet. Super sturdy and protects the rear end of the bed.
The rock sliders are made of round and square steel and are directly welded to the frame. They are super solid and airy enough to look scale.
Now I am working to close the nasty mounting holes in the hood and on the side doors. Soon there will be two main gear options arrive which I will test. Current setup I don’t like. The angle of the Universal shaft from the Disruptor to the Killer TC does not seem right because there is no smooth driving possible. So there will be an update soon.
I am sure I forgot the one or the other thing to mention, but in general this is my super slow Hilux build thread J
Comments welcome.
Thomas
Now the pictures.....
ThomasR is offline   Reply With Quote
Old 10-13-2012, 01:03 PM   #2
heinie_21's Avatar
Default Re: The Hilux Trail Rig
lovin the chassis color. and i'm a fan of the rcmodelex stuff as well. the downside how much they weigh haha.
heinie_21 is offline   Reply With Quote
Old 10-13-2012, 01:35 PM   #3
Exactly this is what I like (beside the look and quality of course) on the rcmodelex stuff. The weight. The more the truck weight, the more realistic it runs. Especially when running a truck with leaf spring setup.
Old 10-13-2012, 02:06 PM   #4
dezfan's Avatar
Nice work, usually not a fan of OD green, but it looks perfect for this build. The stance is spot on as well!
dezfan is offline   Reply With Quote
Old 10-16-2012, 09:12 PM   #5
I'm HUGE in Japan!
ScaleDustin's Avatar
X2 I think the addition of the white topper sets off the green and gives it a super real look! A+
ScaleDustin is offline   Reply With Quote
Old 10-17-2012, 12:49 PM   #6
great looking yota! i love the 1.55 tires on there! the trannys make a lot of noise dont they!! lol
blakeski is offline   Reply With Quote
Old 10-18-2012, 08:32 AM   #7
Did not have the chance to run the truck often. So actually I cant really say much about the tranny. When I have the new transmission I will be able to do more tests.
Old 10-25-2012, 08:35 AM   #8
Keep it up build is looking great!
Falon is offline   Reply With Quote
Old 10-28-2012, 06:37 AM   #9
Whooo hooo! Really cool truck. Me Likey all the details. Great work bro.
Jeepfixer1 is offline   Reply With Quote
Old 10-29-2012, 05:42 PM   #10
Nice looking rig !
nitro5514 is offline   Reply With Quote
Old 10-31-2012, 03:34 PM   #11
Today and the last few days I got one or the other piece for the Hilux.
First two tires to make a set of 4. My previous tires/wheels got my son on his SCX10 Hilux while my Hilux got the old rusty steelies. The steelies were chemical stripped and sand blasted and the weathering process took about one year running in dirt and mud. On front wheels working two scale locking hubs from RC4WD as wheel nut. The bullbar got a whinch and a new 3-speed transmission will find its place in the frame. I just have to shorten the output shafts on the tranny and TC and it will fit nicely. Now I have to make a mount for the transmission. Can't wait to make first test run.
Old 11-11-2012, 05:12 AM   #12
这辆皮卡真的漂亮,very nice。
daxk is offline   Reply With Quote
Old 11-11-2012, 05:47 AM   #13
Whose transmission is that?
Sent from my SAMSUNG-SGH-I717 using Tapatalk 2
adamargue is offline   Reply With Quote
Old 12-02-2012, 03:18 PM   #14
It is from Veroma Modellbau, a german scale model company. Mainly doing stuff for scale Trucks. Very high quality products thay make.
Veroma-Modellbau.eu / Getriebe - LKW - Antriebstechnik - LKW
Old 12-02-2012, 06:01 PM   #15
thing looks sweet
kakachille is offline   Reply With Quote
Old 12-13-2012, 08:15 PM   #16
I joined the Band!
That chassis setup looks good but that trans sets it off.
bayareaaxial is offline   Reply With Quote
Old 12-13-2012, 09:21 PM   #17
Wow that looks just like the one I have now
lets go jeep is offline   Reply With Quote
Old 12-14-2012, 10:09 AM   #18
Hey that one looks familiar! Like heinie's old one Still looks good! And you're right, they do look alot alike
steele42 is offline   Reply With Quote
Old 12-22-2012, 05:15 AM   #19
That's funny. I started my hilux about two years ago (very slow progress - I know) not knowing about that one.
Old 12-23-2012, 04:32 AM   #20
Two of my favorite all time rigs
tozrovr is offline   Reply With Quote
The Hilux Trail Rig - Similar Threads
25 Trucks beach Trail: 15 Land Rover Defender scx10 Trail Finder 2 Wraith hilux Tundr boolean21 Scale Videos! 6 08-22-2012 04:07 PM
a simple trail hilux twilight 1.5 Scale Rigs 12 07-24-2011 09:23 PM
First Scale rig..... X-trail Hilux Rocksolo 1.9 Scale Rigs 30 10-24-2009 09:43 AM
HiluX-Trail Toyota Hilux ToyFarm 1.9 Scale Rigs 34 06-12-2009 11:11 PM
Hilux and X Trail? AeroSynch General Scale Talk 2 04-08-2008 07:38 PM
