Go Back   RCCrawler Forums > Scale Rigs General Tech > 1.9 Scale Rigs
Thread: Old comp truck turned scale truck (the rebuild, AGAIN!)
Old 03-07-2013, 10:48 PM   #1
Default Old comp truck turned scale truck (the rebuild, AGAIN!) More carnage!
Well another year has passed and it's time once again to rebuild my trusty Toyota. I love this truck too much to let it go and i have some plans for getting yet more scale points
For reference here it the last rebuild:
old comp truck turned scale truck (the rebuild!)
First here it is all pathetic looking after i swiped the axles to use under my Scout project.
Then i tore it down to the frame
And after assessing the damage noted 2 places that need attention.
The one over the passenger side i was able to straighten but the one over the drivers side will need to be replaced
Oh and here is the home made T-case still holding up even with sines of wear
It still works so i'm going to stick with it.
Then i laid out what was left. Here are the parts i'm keeping
And the scrap pile
Then i blasted the frame and started the surgery
Some people would have a hard time doing this.
If you followed my last rebuild i just put them on but was never really happy with how the body panels pushed in so easily and i needed room for the drop bed
And just a teaser, Bet you can't guess what this is for
That's it for now!
Metal Masher is offline   Reply With Quote
Old 03-07-2013, 10:50 PM   #2
Default Re: Old comp truck turned scale truck (the rebuild, AGAIN!)
Nice. I think I know what that strapping is for. And if Im right, I'll feel pretty smart.
imthatguy is offline   Reply With Quote
Old 03-08-2013, 11:45 AM   #3
Aw I think the body's the only good thing goin' for this rig
Jokes aside, I do think the "beat up" body looks way cool! If the work you put into that body is any indication of your new incarnation of this rig it'll be awesome.
Cheers,
Doc
doc.hamilton is offline   Reply With Quote
Old 03-08-2013, 11:48 AM   #4
SuperShafty.com
pretty sure i know what the strapping is for!
mjderstine is offline   Reply With Quote
Old 03-08-2013, 12:14 PM   #5
I like the beat up look as well. I know what the strapping is for.
scorpiondave is offline   Reply With Quote
Old 03-08-2013, 12:36 PM   #6
So cool. Real metal siding to take carnage is as scale as it gets. Chicks dig carnage. Cant wait to see the rebuild!
alpine4x4 is offline   Reply With Quote
Old 03-08-2013, 01:38 PM   #7
ahhh yes... i love this truck EVERYTIME you rebuild it!! looks like this time it may have some leaf sprung action..
looking killer dooode!
blakeski is offline   Reply With Quote
Old 03-08-2013, 05:43 PM   #8
Originally Posted by Metal Masher View Post
Looks alot like another Toyota I know.....
Can't wait to see what you do next.
fla_cracker is offline   Reply With Quote
Old 03-08-2013, 08:18 PM   #9
You'll need to stay tuned to find out for sure!
Cheers,
Doc
Thanks! I hope it turns out as good as i plan
Yep. I've been running it this way for a while and just love the realism.
I've thought about making a scale model of that truck and recreating the video sequence and try to get the same carnage. Maybe in the future some time.
Before i did any more work on the chassis i decided to beef up the axles. Call me old fashioned but i like the TLT axles i've been using. i want to add a bit more power so when i saw that RC4WD had there aluminum strait axles on clearance i figured it was the perfect opportunity to add some strength.
Of course as soon as i got it, i started hacking and took the servo mounts off.
Then i shaved the bottom and rounded the edges
The only down side, coming from RC4WD, is that the key mounting features don't match the original axle as evident here where you can see the top holes are in different locations
This meant i needed a new upper truss. so i whipped one up real quick
Then to add strength i drilled and tapped the case
And added a 3rd mounting point
Also the front of the axle has a block of metal that sticks out where the original lower link mount need to be
So i machined the blocks to fit the old lower link mount location and then media blasted the cases
then i drilled and tapped for the link mounts
then I ordered some stainless strait axles and installed them
Brazed and blasted the truss mount
and buttoned up the axle without the pinion just for mock-up
and threw it under the truck
then i also treated the front axle to some upgrades with MIP CVD's, aluminum knuckles, clocked C hubs and Teflon sealed bearings.
That's it for now.
Old 03-09-2013, 04:10 AM   #10
I have a feeling she's getting a makeover for her trip to ECSC...
Rckcrwlr is offline   Reply With Quote
Old 03-09-2013, 08:18 AM   #11
dezmoon's Avatar
Just When You Think It Cant Get Any "Scaler"....Here We Go Again...
dezmoon is offline   Reply With Quote
Old 03-09-2013, 12:30 PM   #12
Sinking with the ship
1BadJeepBruiser's Avatar
Liking the rebuild so far, keep up the good work!
Old 03-09-2013, 03:36 PM   #13
Any paint choices yet?
elsewhere is offline   Reply With Quote
Old 03-09-2013, 05:21 PM   #14
I love this build! Happy to see it coming back to life (again).
Highmark is offline   Reply With Quote
Old 03-09-2013, 07:04 PM   #15
RMK
I'm stoked that I'm finally able to whitness one of your excellent builds from the start. Sub scribed! This is gonna be good!!!!
RMK is offline   Reply With Quote
Old 03-24-2013, 06:41 AM   #16
Sort of, i was already planning a rebuild for this season but decided to step it up for ECSC
I hope i don't disappoint!
Thanks!
I found a few new colors at the store the other day that i'm going to try.
Me too!
Well here is some more!
I guess it's time to reveal the purpose of the coil. Yes they are going to be used as leaves but in the 1/4 elliptical variety.
I liked how the truck worked on the link set-up i had but wanted to get the extra points so i figured i would give this a try.
I started by making the plates to mount the leafs
then i cut a slot in the chassis for the mounts
After some more measuring i figured i needed to cut more out of the chassis
Then tacked the mounts in place
next i bent the leaves up and placed them in the chassis mount
and the old lower link spot on the axle.
Now the springs will not work as lower links so the next step will be to add links that parallel the springs.
That's all i have so far. Hopefully i'll have it rolling soon so i can see if it works.
Old 03-24-2013, 07:21 AM   #17
Awesome build thread nice to see some people still use Tlt axles
laxjj14 is offline   Reply With Quote
Old 03-24-2013, 08:24 AM   #18
I have been playing with a 1/4 elliptical setup. Keep it up!
doublej is offline   Reply With Quote
Old 03-24-2013, 12:06 PM   #19
a guy in our local club did that on one of his rigs... its deffinatly an old school way but looks so cool!! great work man
Old 03-24-2013, 01:07 PM   #20
Nice work on the tlt axles! I still run them and love them. I want and need More!
simp is offline   Reply With Quote
Old comp truck turned scale truck (the rebuild, AGAIN!) - Similar Threads
Class 3 Yota scaler (another comp truck rebuild) Metal Masher 2.2 Scale Rigs 22 05-11-2014 09:24 PM
old comp truck turned scale truck (the rebuild!) Metal Masher 1.9 Scale Rigs 32 01-02-2013 01:23 AM
old comp truck turned scale truck Metal Masher 1.9 Scale Rigs 50 04-22-2011 01:16 PM
WCC Comp Truck Rebuild Chris_The_Battery_Man General Crawlers 21 06-07-2009 12:43 AM
