06-03-2014, 07:01 PM | #61 |
I wanna be Dave Join Date: Jul 2010 Location: Toronto
| Re: D90 class 1. by mjderstine |
06-05-2014, 11:05 AM | #62 |
SuperShafty.com Join Date: Jan 2008 Location: Visalia CA
| Hey guys. I cropped the top off last night with the Dremel. Got some cool stuff to do on the inside to make it look good but it came off nice and easy |
06-09-2014, 07:31 AM | #63 |
Fan of wheelspeed Join Date: Jun 2011 Location: Southern IN
What's next?
06-10-2014, 11:50 AM | #64 |
I wanna be Dave Join Date: Jan 2006 Location: Iowa, the antirecreation state!
Cool. Time for some tube work?
06-11-2014, 12:21 PM | #65 |
I'm working on the rear interior some. Gonna remove the seats and put some more useful things in there. Also gotta make a simple cage for the driver area. Shouldn't take too long. |
06-12-2014, 11:45 AM | #66 |
| Re: D90 class 1. by mjderstine https://www.youtube.com/watch?v=T-cy...ature=youtu.be got some good video from the last comp at BobRocks two weeks ago. the d90 is in there somewhere. its a pretty well done video... |
08-08-2014, 05:19 PM | #67 |
08-08-2014, 05:19 PM | #68 |
08-08-2014, 06:44 PM | #69 |
Looking good! Where's your trans? Middle or front? I ask, as I want to mention that things are looking a little high overall. Wondering if you can bring the body down at all. |
08-08-2014, 08:02 PM | #70 |
the tranny is up front. i have a transfer case from GCM in the middle. yeah it may be a little high... but it drives like a tank. i've gotten it on some pretty precarious places and it stays where it is. i've got everything about as low as it can go right now. i also think some of the height you are seeing is some optical illusion too. i've got the bumpers and fenders trimmed a bit so that everything articulates without hitting anything. |
08-08-2014, 08:09 PM | #71 | |
| Re: D90 class 1. by mjderstine Quote:
08-08-2014, 08:10 PM | #72 |
of course man. two weeks and you'll be seeing it1
08-09-2014, 02:17 PM | #73 |
Newbie Join Date: Jun 2013 Location: two harbors
Wow that looks great, i want to move my motor up front too, did you use any examples or wing it?
08-09-2014, 08:19 PM | #74 |
I just wung it ;) Look back in the first page or two and you will see how I did the motor mount. |
08-09-2014, 08:38 PM | #75 |
RCC Addict Join Date: Aug 2005 Location: New Oxford PA
Looks great! it'll be fun to catch up at the comp again!
09-23-2014, 05:06 PM | #76 |
hey guys, this thing went through quite a lot of changes before ECSC '14, and most of them did me well. ended up with 4th place in C1. now i am changing a couple other things. i never liked the hard plastic fender flares, so i decided to hack up some Dingo flares and bolt them on. they sit higher, which should allow for a lower stance of the whole truck. it sits just a tad high. i was thinking about getting the Old Man Emu 80mm shocks for it. i figured they wouldnt be worse than stock scx10 shocks that i currently have on there, and they look great. any advice on those shocks? here are some pics of how the body looks with the flares. i also took some time to replace the stock lockers on the things and put some new bearing in the thing. the tranny had two frozen bearing, and i replaced all the bearings in the axles. regreased everything and got it back together. Last edited by mjderstine; 09-23-2014 at 05:10 PM. |
09-23-2014, 06:05 PM | #77 |
I like the OME's. Get yourself the spring collection that comes as an add-on. Gives you few options on spring rate. They're a good shock for a medium to light weight truck. Edit: Congrats on your 4th place! |
09-23-2014, 08:52 PM | #78 | |
Thanks man! You had some great builds there man. So the ome's... This truck isn't that light. It compresses the stock axial springs a good amount already. What would you call a medium weight truck? This one is at least 9-10lbs. The body alone is easily over a pound. Darn hard bodies. | |
10-10-2014, 07:19 PM | #79 |
10-11-2014, 08:50 PM | #80 |
D90 class 1. by mjderstine - Similar Threads | ||||
USRCCA Class 1 - Super Class - Cut N Shut Tire Catalog | Nova's Ark | Crawler Innovations | 32 | 01-29-2023 05:10 AM |
BYB by MJDerstine (with good video) | mjderstine | Kyosho Crawlers | 76 | 07-30-2013 07:23 PM |
How To: Aluminum Body Panels by mjderstine | mjderstine | Paint and Body | 6 | 05-01-2012 07:50 AM |
