04-22-2013, 07:01 AM | #21 |
I wanna be Dave Join Date: Dec 2006 Location: Where the sheep run scared.
| Re: Banana clip is reborn by mtgrizzlymn
Cannot wait anymore. Lets see a roller!!!!!!!!!!!!!!!!!!
04-22-2013, 05:45 PM | #22 |
Rock Crawler Join Date: Nov 2008 Location: missoula
I wish. Super 300 could just throw in 4 more bearings it would be a roller still bugs me they know you will need them.
04-23-2013, 01:20 PM | #23 |
Well got bearings thanks fast eddy! Ill finish front end! Are you guys sure these 300s are all there cracked up to be for the price?
04-23-2013, 03:50 PM | #24 |
Well axles are together and now I need to figure a way to mount the pan hard bar any ideas |
04-23-2013, 09:17 PM | #25 |
Any ideas guys for a pan hard bar, if I had another big link I would just go 4 link and mount servo on axle
04-24-2013, 09:59 AM | #26 |
If you want a bar or an upper link to match send me the demensions. I will hook you up. |
04-24-2013, 11:40 AM | #27 |
You have another pm! Thankyou very much, this guy uses some real rod for links its huge and extremely strong |
04-24-2013, 01:13 PM | #28 |
Banana you say the sheep run scared where u live well they get caught in Montana lol, not by me though unless I'm running that damn exo!
04-24-2013, 01:16 PM | #29 |
Well it's hanging on shocks now |
04-24-2013, 01:34 PM | #30 |
Another pm banana
04-24-2013, 01:35 PM | #31 |
RCC Addict Join Date: Aug 2005 Location: Oceano, CA
just use a small section of angle for your panhard mount, and utilize those two threaded holes in the VP axle housing
04-24-2013, 01:36 PM | #32 |
I have wheels but does it hurt to just drill them that extra mm because I'm not which ones to use wheels are the cool factor to go with bananas paint.
04-24-2013, 01:37 PM | #33 |
RCC Addict Join Date: May 2011 Location: Utah County
Way sick jerp Sent from my SCH-I535 using Tapatalk 2 |
04-24-2013, 04:16 PM | #34 |
Ok guys this is a special jeep, what should I run for power I wan fast and crawl don't care if i have to run some volts to it either its built for it. It's going to sit nice and low but still have decent articulation.
04-24-2013, 09:18 PM | #35 |
Rock Crawler Join Date: Oct 2011 Location: minot
17.5bl
04-24-2013, 09:58 PM | #36 | |
RCC Addict Join Date: Oct 2005 Location: rite here all along
| Re: Banana clip is reborn by mtgrizzlymn Quote:
Since you are not scared of spending $$$ on this project...... RX8/rock412 3300kv on 4s | |
04-25-2013, 02:49 AM | #37 |
Rock Crawler Join Date: Sep 2010 Location: Keego Harbor, MI.
| Re: Banana clip is reborn by mtgrizzlymn |
04-25-2013, 05:20 AM | #38 |
I recommend the MMP caslte/ external bec/ and 13.5 redline. This combo doesnt cost as much and will get the job done. |
04-25-2013, 10:11 PM | #39 | |
Could always go rs pro and 412 on 3s for a bit less $$ the tekin motors always seem to work better with tekin esc's Last edited by halfcab; 04-25-2013 at 10:13 PM. | |
04-26-2013, 01:12 PM | #40 |
Guys need help with the super 300 axles I drilled out to fit but I need more spacing I have to use this size wheel for wraith knuckle. If I use spacer drilled even barrel nut wouldn't fit? Help |
Banana clip is reborn by mtgrizzlymn - Similar Threads | ||||
YellowJacket ReBorn | BasuraBlanco | Axial Wraith | 9 | 10-18-2012 10:26 AM |
BADD's XR reborn | baddman | Axial XR10 | 26 | 09-06-2011 09:26 AM |
KRF 2.2 Reborn | afterdot | Kyosho Crawlers | 5 | 06-12-2009 09:46 AM |
A 2.2 Clod Reborn- | SteedaJeff | Tamiya Clod Buster | 8 | 06-19-2008 10:13 AM |
