05-14-2013, 04:22 PM | #61 |
Rock Crawler Join Date: May 2012 Location: Upland
| Re: Banana clip is reborn by mtgrizzlymn
Where are all the banana hammocks? I don't see the rebirth of the banana hammock in this thread...
05-14-2013, 05:01 PM | #62 |
Rock Crawler Join Date: Nov 2008 Location: missoula
We can make an exception lol this rig wii for sure be a good crawler I hope
05-20-2013, 11:58 PM | #63 |
Waiting on motor and a couple links and this rigs gonna be a driver |
05-22-2013, 02:11 PM | #64 |
Well got my rx8 and a pro 4 3300 or a roc 1800 which do you guys think? And I still Need that sus rod they are so strong I'm hoping he still comes threw for me on that one |
05-22-2013, 08:21 PM | #65 |
Any preferences which is a better all around motor I use the other in my bronco probably!
05-23-2013, 05:44 PM | #66 |
I wanna be Dave Join Date: Nov 2008 Location: Chillin in Utardia
I just read a whole thread on these two motors compared. Seemed the general census was with the Pro4. I have ran the pro4 motor in a beefy wraith....it was one mean bad a$$ motor for sure. Hard to stay of the throttle....just wants to go and go hard.
05-23-2013, 08:12 PM | #67 |
ahhh S^*T Join Date: Mar 2012 Location: in the shop bending metal in Whatcom Co. WA.
well with the 3300 you will be much faster, with the RoC you will be slower and may have about the same torque?? not sure but the main differance here is speed. 3300 may tear stuff up faster but what in the heck is going to break on this rig when it decides it had too much?? LOL... thats some MEAN parts you have. when/if it ever does break you will hear it!! super cool rig. inspiring me for my next build! |
05-23-2013, 08:48 PM | #68 | |
| Re: Banana clip is reborn by mtgrizzlymn Quote:
05-24-2013, 09:05 PM | #69 |
Well it doesn't look like bananaclip is going to have time to make the bulky heavy duty suspension rods so I'm going to try some 1/4 aluminum with revo ends and bend it close to the others. Am I better off just taking the solid Steele rod off and going with all aluminum? I like stuff to match. I think he said he uses 4130 chrome alloy steel if that sounds right!
06-08-2013, 11:13 AM | #70 |
Here's the choice! |
06-08-2013, 01:26 PM | #71 |
Having trouble finding a spot for the rx8 that damn thing is BIG
06-08-2013, 04:15 PM | #72 | |
Rock Crawler Join Date: Apr 2011 Location: SD
Wowe.....where did you pick up those tranny yolk extensions? I'm working on a JK myself on a GCM chassis and the front MIP is barely long enough. This would work just perfect. Btw, cool different look'n JK | |
06-08-2013, 04:42 PM | #73 |
Rock Crawler Join Date: May 2007 Location: floriduh
Probably crawler innovation, super shafty sells them also.
06-08-2013, 05:01 PM | #74 |
They are supershafty 6mm shafts very beefy!
06-11-2013, 12:11 PM | #75 |
| . Getting closer the bad boy is in lol! |
06-11-2013, 11:16 PM | #76 |
That turkey is lipo stuffed! Looks like its going to be beastly!
06-12-2013, 12:19 AM | #77 |
Desert I can't wait to run it! Banana said he would make me to beefy links so I'm hoping! It's pretty much ready but heavy hopefully with weight up front it will be a great crawler nice and low to. How are you liking that jeep? Mine has been trouble free from Ralph great rig. I have one more I traded for with black curries got a Toyota coming from Phil and have a gorgeous set of curries and supershafty for it. It's hard to get them all going I have way to many projects lol
06-12-2013, 12:27 AM | #78 |
Axial jeep steers shock hoops turned out great thanks Ryan.
06-18-2013, 06:37 PM | #79 |
Guys I tried 3 servos last being the 404 oz savox and turs instantly when in air but on ground it has to be moving to turn sharp. I'm thinking when frame was built it wasn't right for the steering linkage. I never did get the other links from Bannanas prev owner so I just used some vanquish I had. It is cms. Is it better to have steering arm mounted closer to servo output like drill another hole in servo arm? The pro 3300 is unreal, damn fine motor there, but useless if I can't steer! If I no ideas Bannana clip will be a peel and all the goodies will be moved to a frame that works.
06-18-2013, 08:08 PM | #80 |
RCC Addict Join Date: Nov 2011 Location: cold state
I'm liking this build so far, keep it up!
Banana clip is reborn by mtgrizzlymn - Similar Threads | ||||
YellowJacket ReBorn | BasuraBlanco | Axial Wraith | 9 | 10-18-2012 10:26 AM |
BADD's XR reborn | baddman | Axial XR10 | 26 | 09-06-2011 09:26 AM |
KRF 2.2 Reborn | afterdot | Kyosho Crawlers | 5 | 06-12-2009 09:46 AM |
A 2.2 Clod Reborn- | SteedaJeff | Tamiya Clod Buster | 8 | 06-19-2008 10:13 AM |
