06-19-2013, 02:16 PM | #81 | |
I wanna be Dave Join Date: Dec 2006 Location: Where the sheep run scared.
| Re: Banana clip is reborn by mtgrizzlymn Quote:
06-19-2013, 02:50 PM | #82 | |
Rock Crawler Join Date: Nov 2008 Location: missoula
06-19-2013, 07:11 PM | #83 |
I took it as a hit. You knew that the rig was built for wraith housings. I love the curries but you cannot expect the links I included to work perfect or at all with them. Honestly, the frame will work with the axles you have if set up properly.
06-19-2013, 08:16 PM | #84 |
I never cut guys love the frame Just pray I can make it work? Frankly your links fit perfect way better than vp if you seen it you would swear the links were made for these axles I mean no binding clearance is great just haveing a steering issue maybe I have to much weight up front!! Don't take it bad bud if it was Bannana Peel it would be in a good way! I've kept your name with it all along to because I'm proud owner of it, it's perfect low cog awesome crawler if I can get it there!
06-20-2013, 12:15 AM | #85 | |
Rock Crawler Join Date: Nov 2011 Location: Kamloops
06-20-2013, 12:35 PM | #86 | |
06-20-2013, 01:13 PM | #87 |
The jeep turns like crazy in the air it slaps from end to end with tires just not on ground 404 oz is way more than my wraith so it has to be angle some how!
06-20-2013, 03:32 PM | #88 |
Well guys I'm going with you on angle I ordered longer vp wraith Ackerman arms and racing steering rod it's shorter should bring steering more out to where servo horn is! Maybe , |
06-21-2013, 07:14 PM | #89 |
I have had the same issue with one of my rigs and a cms is different than a soa set up. you dont get angle issues with soa and a smaller servo will do the same as a big power cms . I used the 8 degree high steer vanquish scx10 kit on the front of my jk brute on 2.2s and it steers fine with a 4 link and cms and the servo is a 288 oz spectrum .the only soa rig I had was a wraith all my scalers have been cms set ups .those longer arms will give alot more leverage than the short ones making alot easier on the servo the only thing is the servo has to throw alot farther to move it full distance. easy peezy
06-23-2013, 01:45 PM | #90 |
Ordered a couple a vp parts to try!
07-09-2013, 04:32 PM | #91 |
Well I did a little grinding so I could mount the servo on the currie and that fixed all problems Bannana Clip was correct I left the cms option if I ever change axles but I dought it, Bannana is still going to make me a couple links to finish it up but I can't imagine a rig that would climb or do better than this rig without a dig or rear steer. This thing is amazing on my crawler trails I have and they are far from easy. First 3 tries up my going to the sun trail it made it with ease where my rubicon with curries has only made it a couple out of prob 50 tries. This thing rocks now steering extremely sharp with 300s od gears and savox 404 oz servo and nice geometry from Bannana clip. Last edited by mtgrizzlymn; 07-11-2013 at 04:21 PM. |
07-09-2013, 05:13 PM | #92 |
Now I get to start on a Toyota landcruiser from scale ready no more can be done to this baby to improve I don't think, would like to adjust the rx8 for throttle control if any one is familiar with that, it would be great. 2 ton is on the trails! 2 ton jeep
07-10-2013, 08:19 PM | #93 |
Guys you get a chance for curries and a low slung chassis like this get it man what a blast now I know why the 300s are so nice |
07-10-2013, 08:34 PM | #94 |
I wanna be Dave Join Date: Nov 2008 Location: Chillin in Utardia
Um finale pics???? Don't leave us hanging we've been watching so long. I love this rig.
07-11-2013, 04:31 PM | #95 |
Heres picts of what i ended up doing! Phil scaleready and Travis bananna clip build some heavy duty stuff cant go wrong with these guys |
07-11-2013, 04:34 PM | #96 |
| as it sits now!
11-28-2013, 09:35 AM | #97 |
Well other than pinions this rig has been indestructible ! Still running great! Took it out last night for 45 min of crawling and tearing around! The pinion issue was rc4wd ones not made for brushless power they said !
11-28-2013, 10:30 AM | #98 |
RCC Addict Join Date: Oct 2009 Location: west coast..
Good looking rig any action shots..
11-30-2013, 06:09 AM | #99 |
I'll get some ! This thing has so much torque glad it has the 300s in it! I don't think I can break it drivetrain and cage lol
Banana clip is reborn by mtgrizzlymn - Similar Threads | ||||
YellowJacket ReBorn | BasuraBlanco | Axial Wraith | 9 | 10-18-2012 10:26 AM |
BADD's XR reborn | baddman | Axial XR10 | 26 | 09-06-2011 09:26 AM |
KRF 2.2 Reborn | afterdot | Kyosho Crawlers | 5 | 06-12-2009 09:46 AM |
A 2.2 Clod Reborn- | SteedaJeff | Tamiya Clod Buster | 8 | 06-19-2008 10:13 AM |
