06-21-2013, 11:41 PM | #1 |
RCC Addict Join Date: Dec 2008 Location: pullin somebody else out of a mud hole
| Moglodyte......1 mog two looks
well time to start another project ( while i still have several others going as well ) , i wanted a mog to go with my other zombie survival rigs . kinda sort of like this ( but a bit different ) i want to build the truck as the camper or survival edition , but i want the camper section removable so the mog has a tube bed on it ( for more performance type runs . well i ended up getting a tamiya mog body , a chassis ( i haven't identified yet ) , along with some other parts . parts list so far tamiya mog body un-identified chassis axial trans w/ steel gears scx-10 axles holmes hobbies trailmaster pro edition either a traxxas xl-5 or sidewinder esc thats it so far now for some pics |
06-21-2013, 11:52 PM | #2 |
| Re: Moglodyte......1 mog two looks
now that i have the body mounts figured out i have to start on the tube work , and making bumpers . after all of that is done i will start making the camper box for the back . i am hoping to have the truck ready ( maybe not the camper part ) for the goal hill run in july . will post more later .
06-27-2013, 10:14 PM | #3 |
well i had some time this evening to work on the mog , so i started in on the cage work . this is my first attempt at bending my own cage so it may not be perfect . i want this cage to remain on the mog even when the camper box is installed , so with that in mind i began my first adventure in cage building . so here is what i was able to accomplish tonight ( all i have to use to bend is a small hobby vise with a suction base ) the cage is temporarily taped together as i don't have a welder , after i get done bending and cutting everything the DMG is gonna help me with the welding job . will post up more as i get it done , thanks for watching the build . |
06-27-2013, 11:05 PM | #4 |
Pebble Pounder Join Date: Aug 2012 Location: Salina
Dang Sam thats gonna be a hot looking rig!
06-27-2013, 11:19 PM | #5 |
| Re: Moglodyte......1 mog two looks |
07-12-2013, 10:01 PM | #6 |
okay so i had a little time to work on the mog , i went over to the DMG to get some help in the cage department ( thanks again jerry ) also he hooked me up with some killer front and rear bumpers ( still have to get the mounting points built ) . i also finished mounting the steering servo and finishing up the steering link , and i mounted up the irok's onto the steelies . okay now for some pics . |
07-12-2013, 10:05 PM | #7 |
07-13-2013, 02:30 AM | #8 |
Rock Stacker Join Date: Dec 2008 Location: Queensland Australia
Looking good, where did you find the digi camo?
07-13-2013, 07:50 AM | #9 |
07-14-2013, 08:01 PM | #10 |
well i got a little bit more done on the mog last night ( no pics yet ) , got the rear bumper cut down to length ( had to cut out between 1 1/2 to 2 inches out of it ) . i figured out how and where to mount the exo rear light bar , and i also figured out the mounting for the front bumper/stinger . gotta fab up some mounting tabs for panels , and maybe some brackets for lighting .
07-22-2013, 12:16 AM | #11 |
07-22-2013, 12:18 AM | #12 |
trying to get it ready in time for the goat hill challenge |
07-23-2013, 10:13 PM | #13 |
okay got a little bit more done ( gonna run it at Goat Hill this saturday ) still have a decent amount left to do but it will wait till after . here are the pics as it sits waiting for Goat Hill ....... still have to install all of the lighting , some more body work , and other details . also still have to build the trailer |
07-29-2013, 04:24 PM | #14 |
well after running the mog at goat hill i can say i am pleased with the performance , it crawled around the varying terain of goat hill very well . still have to finish it up and i will probably add some more weight to the rims or axles ( just to help out with c.o.g.) . i think one of the guys took some pics of the mog on the trails , i will post them up if i can find them .
08-18-2013, 10:54 PM | #15 |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
I have to say, quite a unique Mog Viper...I really like the stance. You mentioned in my thread that the wheel base was 13.5". ...is that true? A relaxed rear shock (laid down) would be soft in the rear. I struggled with that in my build... It looks great...looks like it would crawl well, how does it work for you ?? |
08-18-2013, 10:56 PM | #16 |
have a plan in the works for the interior , soon to be hooked up by Dinky R/C . i also have plans to make some panels for the underside of the cage as well as some mesh panels for the sides ( probably some solid ones as well )
08-18-2013, 11:03 PM | #17 |
Keep it up...post pictures... Looks are great....BUT The performance meter is on |
08-18-2013, 11:09 PM | #18 | |
| Re: Moglodyte......1 mog two looks Quote:
08-18-2013, 11:12 PM | #19 |
03-23-2014, 11:21 PM | #20 |
well no new pics but i did put it back together after an extended time being torn apart . ran the mog at our first comp/scale run last saturday and it performed well as usual .... i will be starting on the panels for the cage and the survival camper for the back . gotta figure out where to move the battery holder under the cab and make some chassis extensions for the side to fill in the gap from frame to body .
Moglodyte......1 mog two looks - Similar Threads | ||||
my camper mog and my 4 doors mog in my scale garden | doudou | 1.9 Scale Rigs | 25 | 05-24-2013 05:58 PM |
My Mog | totalamature | Tamiya CR-01 | 19 | 05-14-2013 12:35 AM |
The MOG is out !!!!!!!!!!! | Joat | Tamiya CR-01 | 2 | 09-27-2008 04:20 PM |
