05-04-2014, 07:52 PM | #141 |
RCC Addict Join Date: Nov 2010 Location: nashville
Looking good man. Can't wait to see what bumpers you build for it. Keep up the great work.
05-22-2014, 12:27 PM | #142 |
I wanna be Dave Join Date: Jan 2004 Location: Austin Texas
| Re: KC's 2014 RC4WD ECSC 2DOOR JK
Any updates dude?
05-22-2014, 12:38 PM | #143 |
Rock Stacker Join Date: Feb 2013 Location: Northern Ireland
X2 |
05-22-2014, 01:55 PM | #144 | |
RCC Addict Join Date: Aug 2010 Location: wherever paypal sais.
| Re: KC's 2014 RC4WD ECSC 2DOOR JK Quote:
Man i wish i had some updates.. still waiting to get my steering links back and been crazy busy helpin my preg wife n takin care of my daughter. Gonna get some work done this weekend for sure. I got 4 days so 1 of em is def gettin dedicated to the rig. But.... thx for thinkin of this. | |
05-22-2014, 07:31 PM | #145 |
Pebble Pounder Join Date: Sep 2010 Location: Santee
Sexy rig. Im in love with those axels
05-25-2014, 09:58 AM | #146 |
Thx myth! Me too haha.. So some updates.. small but updates. Got the motor and esc mostly wired up. Using a piece of shit iron made it very painful.. and in order to reduce the amount of wire for the servo bec splitter and winch controller i orderrd servo plug blanks. Male and femal side. Including pins and recievers for the wires. I should be able to really cut down on the amount of wire needee and save some room. Also got the cowl from vengeance made up. Its slightly tapered in from back to front and the backside is undercut. Came out well. Need some filler to smoth things out where it meets the body. I used regular pvc cement to adhere everything together. Works like a charm. And unlike tenax 7 its a gel so you can control where and how much is applied much easier. |
05-25-2014, 04:36 PM | #147 |
I wanna be Dave Join Date: Nov 2005 Location: Here
Not sure how I missed this one. Travis, you have been a busy bee. I love LWB Jeeps. Miss my green one. I'm sub'd now.
05-25-2014, 04:42 PM | #148 |
| Re: KC's 2014 RC4WD ECSC 2DOOR JK |
05-25-2014, 11:04 PM | #149 |
had about an hr of free time today so I whipped up the rear anti rock setup. went to a local hobby shop and picked up a length of 3/32 piano wire. when I got home I decided where I wanted it to pass through the chassis. that just so happened to be right where a hole already was, so I drilled them out to 3/16 and brazed in some tube to act as the torsion rod guides. then I measured the length the torsion rod needed to be and ground flats for the wraith anti roll arms to attatch. once I had all that done the rod was just to stiff. so I chucked it up in my drill and used my dremel to reduce the overall diameter in the center section about 3.5 inches total. made it less stiff which is what I wanted. im doing this mostly cause my shocks are inboard mounted and that type of setup can get sloppy sometimes so this will keep the rear under control. once testing begins I may reduce the shafts diam. again to get it where I like it. anywho enough typing heres the pics. |
05-25-2014, 11:29 PM | #150 |
I wanna be Dave Join Date: Dec 2009 Location: Outside DC
Shouldn't you be out tire shopping? There has to be something new out there! |
05-26-2014, 09:07 AM | #151 |
05-26-2014, 10:11 AM | #152 |
RCC Addict Join Date: Apr 2011 Location: San Diego
05-26-2014, 12:55 PM | #153 |
05-30-2014, 04:58 PM | #154 |
Got my links back and got the wiring to functional point. Did some playing on my pile to test the roc412. 1 word 3 syllables Ahhh...maze...ing! Only 1 prob.... gotta wait for my tekin hot wire to reverse motor rotation. My esc doesnt have the firmware to do that via stick programming. And lemme tell ya... this thing crawlsx climbs and overtakes lije a freakin dream.. see yall in aug.... KC out |
05-31-2014, 09:39 PM | #155 |
Good to hear its working out like you wanted! Can't wait to check it out in person. That back Part of the frame is wild! |
06-01-2014, 03:14 PM | #156 |
Rock Crawler Join Date: Jun 2013 Location: Cincinnati
ROC412? I'm jealous! Sent from my iPhone using Tapatalk |
06-01-2014, 04:53 PM | #157 |
I joined the Band! Join Date: May 2006 Location: Between a rock and a hard spot!
06-02-2014, 02:49 PM | #158 | ||
Yuhp... lol Quote:
But on another note sone goodies came in today. Gonna place a order for some more batts as the ones i got are old and a bit swollen... argghhh... Got a Tzi world beefy winch and my tekin hotwire. Yay adjustments! And pulling power for sticky situations. Gonna be mounted in the very back of the jeep. Gotta get a heyok 4amp fuzed winch controller. Gonna run this on a small 2s pack ill stash in the back as well. | ||
06-04-2014, 08:18 AM | #159 |
Pebble Pounder Join Date: Feb 2012 Location: Freakville
Ive been looking at the TZI World Winch but with running the Dinky Divorce Kit I dont think Im going to have the room up front. Id love to see how youre going to mount this to potentially give me some ideas.
06-04-2014, 09:09 PM | #160 |
| Re: KC's 2014 RC4WD ECSC 2DOOR JK Its gonna be mounted in the back with a guide leading to the front. ill post pics whens its done
KC's 2014 RC4WD ECSC 2DOOR JK - Similar Threads | ||||
Chad30w 2014 ECSC pig killer....... | chad30w | 2.2 Scale Rigs | 60 | 11-13-2015 06:16 PM |
Trialpsychos Poison Spyder jk 2door -- Asts comp car 2014 | trialpsycho | Axial SCX-10 | 11 | 10-22-2014 03:49 PM |
2014 ECSC Silverado Build | teifert2429 | 1.9 Scale Rigs | 7 | 07-31-2014 02:28 PM |
