06-26-2014, 03:25 PM | #1 |
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
| Codyboys T-Rex The Green Machine.
Went to a new owner today. I have been working on this off and on for about three weeks, so thought I would try another build thread. I wanted to build something with about 11.5 wheel base and a hard body. I started with a Newbright body and streched it one inch. I did a comp cut on the rear and a partial on the front. Here is my parts list: - Stock SCX10 chassis - Super Shafty bullet proof transmittion - Tekin PRO 4 3300 kv motor - Kyosho Velvet shocks front and rear - For now 4 link front and rear ( may change to three link in front later) - Front axle is RC4WD Black Widow - Rear axle for now is SCX10 with beef tubes and up graded locker and gears - Custom transfer case I made at Kelly Lunsfords shop - Motor forward with custom mounts - Wheels are by Locked up RC I have five of these - Tires are RC4WD 1.7 IROC Super Swampers with home built two stage foam - A front winch - Fuel cell Things I plan on building: - Stainless steel Boatside rock sliders (stainless because I don't plan on painting them) - 3/16 stainless steel pick-up stile cage with a soft top - Stainless steel steel armor with comp fender for the rear - And what ever suggestions you guys might have And I want run it low and mean with about 3/4 droop. - - Last edited by CODYBOY; 03-09-2015 at 10:54 PM. Reason: adding photos |
06-26-2014, 03:29 PM | #2 |
| Re: Codyboys T-Rex The Green Machine. |
06-27-2014, 12:46 AM | #3 |
Quarry Creeper Join Date: Apr 2011 Location: Waimanalo, Hawaii \m/
what green is that? its looks really good.
06-27-2014, 08:12 AM | #4 |
Thanks, it is Tamiya candy lime green (TS-52) and I put down a coat of gold first. Another photo of the color. Last edited by CODYBOY; 06-27-2014 at 03:42 PM. |
06-27-2014, 03:47 PM | #5 |
06-28-2014, 11:36 AM | #6 |
06-28-2014, 12:31 PM | #7 |
RCC Addict Join Date: Oct 2012 Location: Charleston South Carolina
Incredible cage work!
06-28-2014, 01:08 PM | #8 |
07-03-2014, 08:56 AM | #9 |
07-03-2014, 11:57 AM | #10 |
Quarry Creeper Join Date: Dec 2012 Location: ontario
Your Rig Is Coming Along Very Nice ! |
07-04-2014, 09:32 AM | #11 |
07-13-2014, 06:23 PM | #12 |
It has been a few days, so thought I would share some progress. Had to make a shaft for gear box to transfer case. I used losi shaft ends, cut and soldered to length. Last edited by CODYBOY; 07-13-2014 at 06:58 PM. |
07-14-2014, 04:57 PM | #13 |
07-14-2014, 05:12 PM | #14 |
Rock Crawler Join Date: Feb 2014 Location: ?
Very sanitary work. Love that green.
07-14-2014, 09:13 PM | #15 |
I joined the Band! Join Date: May 2009 Location: lake county ,florida
Looks stellar, glad to so the rear axle this time.
07-14-2014, 09:21 PM | #16 |
Finished up the rear body armour and changed the shocks from 3.5 to 3.0 today. Trying to keep the cog as low as I can. Because of the off set punkin in the rear I had to move the shocks from behind the axle to the sides of the chassis. It is amazing how one small change leads to another ,and then another. But it is starting to look like a roller. The tool box will cover up the shock mounts behind the roal cage. |
07-14-2014, 09:38 PM | #17 |
Awesome Rig You have There Sir ! |
07-14-2014, 10:11 PM | #18 |
| Re: Codyboys T-Rex The Green Machine. Thanks, I really like to do the detail work, and the color is my favorite. Thanks for the compliment, I wanted to try and do something a little different than my last build. |
07-15-2014, 03:56 AM | #19 |
Rock Crawler Join Date: Jan 2013 Location: Australia
wow, really nice body work!
07-16-2014, 07:09 AM | #20 |
Codyboys T-Rex The Green Machine. - Similar Threads | ||||
JK my way green machine | matt_22 | Axial SCX-10 | 73 | 03-11-2013 10:40 PM |
the green machine | artl666 | Paint and Body | 0 | 02-24-2013 04:01 PM |
Mean Green machine | Peaker | Scale Videos! | 3 | 07-18-2011 06:53 PM |
The Green Machine Rebuild | Whirlybird | Axial AX-10 Scorpion | 11 | 07-29-2008 09:53 PM |
the green machine! | gearmonkey23 | HPI Wheely King | 6 | 03-05-2008 07:13 PM |
