12-09-2015, 11:40 AM | #21 |
Pebble Pounder Join Date: Jul 2014 Location: Phippsburg, ME
| Re: Slow 1/10th scale aluminum ZJ body build.
I made a few minutes to tinker again. After looking over the pics from my last post and seeing the Wraith sitting behind it I decided to take the V8 radio box out of the Wraith and install it in the ZJ's incomplete engine bay, so I can work around it and not crowd it's space too badly. Then I stuck the AR-3 receiver to the underside of the intake manifold lid and stuck the antenna out through the hole from where I trimmed the back corners of the cylinder heads to clear the body post mounts on the shock towers. EDIT: I forgot to mention that the top flange of the front bracket is folded around the top lip of the firewall and glued as well as crimped onto that lip. Plus the V-8 is tilted back at about a 4 degree angle, like the real thing. LOL Last edited by Full Throttle Rob; 12-09-2015 at 02:16 PM. Reason: forgot stuff |
12-09-2015, 01:20 PM | #22 |
Pebble Pounder Join Date: Jul 2015 Location: Fort Collins
I'm not typically a big Jeep fan after owning a 1:1 JK... for obvious reasons.... But I think you are doing a kick ass job with this custom build and I'm watching now for sure. Sub'd. Keep up the awesome work.
12-10-2015, 06:39 AM | #23 |
So, I knocked the rig off my desk and onto the floor... Luckily it landed on the rear end of the frame and not my door openings!!!! Though the impact did break the mounts off the V-8, so I had to put it back in place with some metal under it for strength. After that I decided it was time to put in the transmission and drive shafts so it won't roll off again..... I traced around it and cut a hole in the floor to fit it in. I should have mirrored my transmission, as I would have more room in the front. I prefer more weight in the front for helping keep the nose on the ground on those really steep climbs. If I am putting the battery in the front it will have to go way up front at a 45 degree angle. This will keep me from being able to have a steering wheel that moves along with the wheels using a mini servo. The battery barely fits in the body between the door openings, so I'll have to figure out something magical to keep the wires from interfering with the opening and closing of the door. I really don't want the battery in the back, but there sure is a lot more room for it back there. Last edited by Full Throttle Rob; 12-10-2015 at 06:45 AM. |
12-10-2015, 07:42 AM | #24 |
RCC Addict Join Date: Sep 2015 Location: Southern Maine
A mini lipo pack would help out greatly with battery placement and they don't weigh much so not as important if you mount it out back. Awesome job on the metal work though! Ben |
12-10-2015, 07:52 AM | #25 |
Thanks Ben! I'm not even considering switching over to lipo, to be honest with you. I have horrible luck as it is, and I don't need to push it by owning batteries with a high potential for catastrophic failure. I'll stick to the good-old heavy nickel batteries, just for the added peace of mind!! |
12-10-2015, 07:20 PM | #26 |
| Re: Slow 1/10th scale aluminum ZJ body build. |
12-10-2015, 08:14 PM | #27 |
Pebble Pounder Join Date: Jan 2015 Location: Sydney
| Re: Slow 1/10th scale aluminum ZJ body build. by the way, Would you consider moving the transmission to the front?
12-12-2015, 08:04 AM | #28 | |
| Re: Slow 1/10th scale aluminum ZJ body build. Quote:
I'll leave the trans where it is, put the battery directly in front of it, and go without a moving steering wheel. No big deal! So, I made some inner wheel wells and a passenger's side inner rear quarter and proceeded to install them all. I (poorly)folded the cargo area floor flanges back down and put the wheel wells in place, followed by their respective rear quarters. It's slowly starting to resemble a vehicle now. | |
12-13-2015, 10:31 AM | #29 |
Quarry Creeper Join Date: Jun 2008 Location: San Antonio
Wow! Awesome build! It really is starting to look the part with it sitting on the chassie! Nice job |
12-13-2015, 06:20 PM | #30 |
I will recommend installing an internal rollcage, from what I have learnt this weekend...... |
12-14-2015, 04:51 AM | #31 |
12-14-2015, 06:24 PM | #32 |
Quarry Creeper Join Date: Feb 2008 Location: The Schwa
I can't believe this styrene work. Mind blown!
12-15-2015, 03:54 PM | #33 |
| Re: Slow 1/10th scale aluminum ZJ body build. Thanks for the compliment but it's aluminum trim metal, not styrene . Styrene wouldn't last 60 seconds with me behind the wheel.... The aluminum might last 90 seconds.... Last edited by Full Throttle Rob; 12-15-2015 at 07:05 PM. Reason: typo |
12-15-2015, 06:56 PM | #34 |
So, last night I spent 3 hours making the pattern for the cowl, inner fender tops, and radiator support top. I traced a diagram of the hood opening structure onto graph paper, drew out tabs, and figured out my bends. The diagram was mis-shaped so when I folded it in half and put it on the tracing table the two sides were not exact. I split the difference of the two sides and had to recalculate the whole damn piece. LOL I cut my pattern out with it folded in half, so it is identical on both sides. This afternoon at work was kind of slow(meaning I put off actual work to tinker with my stuff) and I successfully made and bent up my part on the first try!!! Kaler got to watch the process of my madness. I got a little bit ahead of myself and made a headlight/turn signal/corner marker lens out of some 0.040" Lexan. Kaler had to do some frame and cage straightening on his "Beater" after his latest "I got this!!!" episode, so I mocked it up like I'm running it over. I can hear Jeff cringing about it now.... Last edited by Full Throttle Rob; 12-15-2015 at 08:21 PM. Reason: typo |
12-15-2015, 07:34 PM | #35 |
Pebble Pounder Join Date: Nov 2013 Location: Bath,ME
Ya I've gotta stop having "i got this!!" moments. It's very cool to see the metal madness, it's a very unique project and im glad to see it first hand as it developes.
12-19-2015, 06:47 AM | #36 |
So, I made the last cargo area floor piece, the inner half of the radiator support, and the bottom of the radiator support. The inner radiator support has 19 bends in it, and it actually worked out as I had planned! I was shocked!!! Planning out the front half of the radiator support with the grille opening and headlight/turn signal/corner marker buckets will probably be next on the agenda. Stay tuned! |
12-19-2015, 07:39 PM | #37 |
So, today I traced my door openings and plotted out my inner door skins. These should be real interesting to bend up... Then I got to looking at the lexan lens I had made a few days back and decided I needed to make a housing for it. Then I did a little trimming to make it fit where I wanted it. Then I had to make a matching one for the other side so it wouldn't look so stupid. |
12-20-2015, 12:06 PM | #38 |
Last night and this morning I made the front half of the radiator support. It didn't come out as well as I had anticipated, but it will serve it's purpose. It's looking like I'll have to build a really thin grille out of thin styrene strips just to visually cover the front half. I'm hoping to have some time to work on it some more tonight, but my spousal unit just informed me that we have a ton of X-mas gifts to wrap tonight........ |
12-20-2015, 01:19 PM | #39 |
So, I got(made) a chance to bend up the driver's door inner skin, and it fits pretty nicely!! Although, I got a little confused and scored it along a bend line for about an inch.... Which means I'll probably decide to start this piece again. Or reinforce the crap out of it instead.... I still need to cut and fold the window opening. |
12-20-2015, 04:32 PM | #40 |
A few weeks back my wife went through all of her empty jewelry boxes she had been saving for a decade or two, and got rid of them. Being crafty(cheap), I decided that the jewelry box hinges would work fine(minus their springs) for my ZJ doors and hatch, so I saved 4 hinges that were identical for the doors and a few others for the hatch and hood. I rigged it up temporarily and it works pretty friggin' awesome!! Door reinforcement, door outer skin, and a latch system are needed but you get the idea. |
Slow 1/10th scale aluminum ZJ body build. - Similar Threads | ||||
10th scale rules for a build | Bamfapotamus | Newbie General | 2 | 03-05-2009 01:31 PM |
1/10th Scale Tonka Build | edward87 | Newbie General | 14 | 07-29-2007 10:51 AM |
1/10th scale body | srfrkyle1234 | Newbie General | 4 | 11-21-2006 10:06 AM |
