Go Back   RCCrawler Forums > Scale Rigs General Tech > 1.9 Scale Rigs
Thread: Cherokee XJ Hardbody Class 1 Build
Old 06-04-2016, 08:33 PM   #61
Default Re: Cherokee XJ Hardbody Class 1 Build
I got the interior in today. All looks good except the dash had loose fibers. I hit it with some heat and it was fine.
I'm not going to do a complete photo shoot of it unless someone asks.
I started to do a video for it.... but i soon came to the conclusion: I don't have that much to say about it.
It doesn't come with hardware. But if you have this body, you have a whole mini-bag of suitable harware. For the head rests, use piano wire ("music wire" if you go to lowes). I love that stuff, super useful.
Now, if you've made it this far, thanks.
I need some feedback on this. I've never finished a 3D part. I knew sanding would be involved because of the stepping. There's no way you could just paint this set out of the box and have it look good. But that's standard.
Is the liberal use of putty normal? I imagine if done right, it will create a very smooth and nice finish.
These are in the middle of being puttied.
This is going to be a lot of work... but that's what it's all about.
Dustinf is offline   Reply With Quote
Old 06-08-2016, 11:25 AM   #62
Just placed an order for one of these body's, as it was a very good deal, Not even sure what chassis I'll use. Who printed your interior? Most of my small 3D parts I have done in transparent acrylic which yields lots of detail. So far I'm not seeing anyone who produces a full interior except for Pro line's version. Looking really good so far.
tokdl is offline   Reply With Quote
Old 06-08-2016, 12:34 PM   #63
coulda used acetone... but hey we learn something new everyday! here is for your future of owning 3d printed parts.
https://www.youtube.com/watch?v=9qByAGrbmS8
or even use Tamiya surface primer.
but your way is good too. just note over time.. your putty will shrink down a little bit.
CM9000 is offline   Reply With Quote
Old 06-08-2016, 07:56 PM   #64
The interior was printed by R3scaledesignz. You have to contact him on Facebook.
https://m.facebook.com/story.php?sto...49116835196471
Definitely a nice body at any price.
Old 06-08-2016, 08:03 PM   #65
I looked into the acetone method. It's really ingenious in a way. I was worried about detail though. I may use it on the seats.
In this process of smoothing the interior, I find I'm sanding almost all the putty away. Now I've resorted to just sanding on many of the parts, seems to go quicker and much less messy.
Old 06-11-2016, 07:29 PM   #66
I have finished both rear wheel wells. I realized that a real 96 cherokee has a cutout for the back seat, so I added that. It makes the seat fit much nicer.
I originally wanted to put the rear seat on hinges, like a real one, so I could fold it down and have it look right. But the seat is too large for that no matter what I do.
I am making the floor so I can pull out the rear seat and have it look like it is just tucked away. I run my cherokees with the rear seat folded almost 100% of the time. It just looks nicer and I love the space.
Here is the cutaway. It's a bit squared... but squared is in my skill set. This is only my second styrene project after all.
I admittedly got a bit heavy handed with the file/sandpaper. But this is all going to be painted and covered with carpet anyway.
Here is the seat, just sitting in place. I havnt glued the main floor
It's actually starting to look like something..
Old 06-12-2016, 06:18 AM   #67
Agreed. Thanks for pointing me in the right direction. Will certainly use this thread when the time comes to build my full interior.
Old 06-18-2016, 07:55 PM   #68
Just a brief update.
I've been working on the rear interior panels.
This is just the basis starting panels. I'm going to add layers and cut outs to match a 1:1 cherokee. Also notice the light bucket. In hindsight, I shouldn't have made it square, as the real ones have a slope to them.
Here is the panel uninstalled and pre layer. Kind of weird looking.
Old 06-22-2016, 10:31 PM   #69
Finally finished one of the panels. And it's the one that will be covered by the spare tire... but at least it will look good underneath.
I originally wanted to do the same cutout/compartment of a 1:1. But it just didn't look right so I settled with this.
I cut holes in the middle layers. Chambers to help keep the weight down. I don't mind a heavy rig, but at this rate, this thing will be 15lbs+.
And with the spare just sitting there. I don't know how I will mount it yet. It's hollow, so I'll be able to keep something in it. Maybe the light system. I'm also going to cover it in carpet like the other parts.
I'll do the next side and move onto the rear hatch.
Old 06-22-2016, 10:50 PM   #70
My 1:1 was leather on the spare cover
Sent from my LG-H900 using Tapatalk
wblteen is offline   Reply With Quote
Old 06-23-2016, 12:08 PM   #71
Good call, I've seen it go both ways. But leather might look better in small scale.
Old 06-24-2016, 07:11 AM   #72
So much detail!!! Looking forward to more updates
NeedDirection is offline   Reply With Quote
Old 06-27-2016, 11:00 PM   #73
One more piece to the puzzle. Rear hatch.
Turned out alright. The fit is really nice. It will glue onto the rear hatch.
I'm making sure the windows will fit while I'm doing this. I havnt started cutting the lexan yet, I still have a bit of trepidation towards the glass.
This is what the back of this panel looks like.
It's slow going.
Old 07-04-2016, 08:36 AM   #74
I'm currently taking a week off of this build to avoid getting burnt out.
Figured I'd use this time to work on a diorama for my 1:6 collectables and catch up on the bows I need to finish.
Old 07-13-2016, 12:23 AM   #75
I decided to go with a gimmicky smoking exhaust once again. This one will be much nicer. I was able to muffle it almost completely and I'm placing the unit in the feont. This way I can run a scale pipe all the way back. Maybe even add a muffler to change the sound.
It's two units that sit on either wheel well. This should still allow room for one of my horn units.
Old 07-20-2016, 08:28 PM   #76
Back to it, finially.
I'm honestly overwhelmed by the amount of work this thing is going to be to finish.
I finished getting the spare mounted. I had the round part from some tamiya parts tree. I just needed to make a cap. I did that my mounting a piece of styrene to a dremel and sanding it perfectly round.
It has plenty of space inside. I believe I will use this store my light system.
I also made same pieces for the front. This is what I will mount my dash to. It took me awhile to figure out, and I'm not sure if it is the right choice (having the dash be part of the chassis, not attached to the body), but time will tell.
As of right now, everything feels solid.
Old 07-30-2016, 10:56 PM   #77
Thanks for checking out the build guys. It's a long process.
I got the dash installed. This way I can start setting up the seats and finish the interior.
I decided to make the dash part of the chassis rather than attach it to the body. I'm trying to do that with as much as possible.
If thing thing needs maintenance once finished... it's going to be a pain to take down. It is all made to come apart in a clean way though. Actually, the entire interior including wheel wells comes off as one piece. As of now it takes 16 screws, however.
Old 08-03-2016, 12:33 PM   #78
I decided that I should probably wire this thing as it has yet to drive an inch using it's own power.
I've always been obsessive about clean wiring. So I cut short every wire to the length it needed to be. I also hate spliced wires so I take apart the plugs and rewire them.
I ran into a couple issues with space and had to cram a bit.
I like having a switch to shut the vehicle off. Plus, I run a high volt servo and wire it direct. So I put one underneath the transmission.
Now that it runs I can get back to the interior.
Interior pieces should be in this week.
Man I had a 1990 Cherokee with 35-12.50 BFG mud-terrain ta's and I could go anywhere right up till I threw a set of BFG A/t ta's on it.
This is pretty scale and I like the cantilever suspension. How wide is it?
BigNblue is offline   Reply With Quote
Old 08-14-2016, 01:01 PM   #79
I love the Ta's, but I'll have to check out the at's you mention.
It's not very wide. I get nice tire tuck with this set up. I'll measure tonight and respond.
Old 09-05-2016, 10:28 AM   #80
This is the most glorious wiring job I've ever seen
Sent from my SM-T320 using Tapatalk
dpcardoza is offline   Reply With Quote
Tags
cherokee, class, hardbody, jeep, scale
Cherokee XJ Hardbody Class 1 Build - Similar Threads
Just saw this on FB - cherokee XJ hardbody Noll11 Paint and Body 239 03-07-2017 09:02 PM
Nappy's Class 1 Cherokee build "Frank" Nappy Axial SCX-10 7 01-22-2015 10:58 AM
cherokee hardbody? Stitch General Scale Talk 6 12-03-2008 02:07 AM
