Go Back   RCCrawler Forums > Scale Rigs General Tech > 1.9 Scale Rigs
Thread: 1986 Toyota IFS build
Old 11-05-2016, 09:59 PM   #1
MWRCA'er
Mnster's Avatar
Default 1986 Toyota IFS build
I've been craving a IFS build lately. I loved the way my CC-01 would crawl with fitting IFS realism as I've long been a import 4x4 fan. However, I've been restricted build wise with the small cc-01 1/12 size and poor kit construction. I've always thought a properly scale and sturdy design would likely do quite well and if not it would be unique to drive among my other builds creating a fresh driving experience.
Sure, Twin hammers, Yeti, Score truck, kits are out there. They are either to big or don't seem to have the correct scale character for a 1.9 scale truck build.
The new Proline Toyota shell is pretty popular among locals. I bought one the day it was released. I really want to use it but I want it to seem unique while using it. IFS is the answer.
The new Scx10II axles really opened the door for me on this project. With the small compact ring gears suddenly it doesn't seem as hard to mock up into a scale appearing IFS setup that has performance potential. So I've ordered the parts.
So far I have ordered:
Scx10II axles
Yeti C-hubs and knuckles
MIP Slash 4x4 front driveshafts
Proline Toyota body
SCX10 Transmission
Mnster is offline   Reply With Quote
Old 11-06-2016, 09:10 AM   #2
Default Re: 1986 Toyota IFS build
Sounds like a cool build. It will be neat watching it come together
hairba11 is offline   Reply With Quote
Old 11-06-2016, 12:22 PM   #3
Here is a pic of my ifs 4Runner. Cool build man.
bagelbreakhq is offline   Reply With Quote
Old 11-07-2016, 10:01 AM   #4
I'm curious to see how you make it work. I'm trying to figure out a better setup for my humvee build with ifs/irs. So far the best i have is a stretched 1/16 slash 4x4 that its sitting on now, but its severely lacking in the steering and looks departments.
rock_starr is offline   Reply With Quote
Old 11-08-2016, 05:55 AM   #5
Sinking with the ship
1BadJeepBruiser's Avatar
This is going to be full of win Ill be watching closely
-Mike
Old 11-10-2016, 03:18 AM   #6
MWRCA'er
Mnster's Avatar
I set out with the intension to build the drivetrain as beefy as possible to avoid any weakness. So the MIP driveshafts seemed like the ideal choice. No weak dog bone end and a high quality slider to avoid binding. The problem is nothing ever just bolts up.
The factory yokes for the Slash put the outputs to far out. If I mounted them in this position, the suspension arms would have to be pretty short and the bulkhead wide due to clearances.
So I bought some Slash rear stub axles. I plan to machine these to fit the axial locker and reduce the diff output width by almost 1".
I remachined the stub axles to fit the Yeti knuckle assemblies. The Yeti knuckles have the bearings closer together. So making it fit required a bit of filing while being spun in a drill.
After I make the shorter diff outputs it should come close to 7 5/16" hex to hex the width of the rear axle.
Old 11-10-2016, 06:02 AM   #7
Awesome, glad you were able to figure it. Itll be stout for sure with the MIPs. These are the types of builds I love to follow
Old 11-10-2016, 01:55 PM   #8
MWRCA'er
Mnster's Avatar
Thanks! The wheels came today. I wanted something sort of 90's SR5 looking while having a slightly more modern racing look. I think these will give it the right appearance.
Still unsure of the tires I want to run. Something meaty but not to tall or short. Once the build gets further along I'll have to figure out sizes.
Old 11-10-2016, 02:20 PM   #9
Run the 4.19 baja claws.
Old 11-10-2016, 05:16 PM   #10
Awesome! Ive started and failed to complete many times to create a capable IFS rig, My first scale rig was way back when, but durability and performance were lacking with what I was working with.
Ill be interested to see how this plays out
XSRCdesign is offline   Reply With Quote
Old 11-10-2016, 05:34 PM   #11
I like what your doing with this one! I have a new set of MIP slash stubs that I will donate to the cause if you want them. I have no clue how I ended up with them I've never owned a slash.
Bananaclip is offline   Reply With Quote
Old 11-11-2016, 02:07 AM   #12
MWRCA'er
Mnster's Avatar
I sized up some tires. Looks like I need some 4.25" tires to give a good balance of scale and performance.
The Flat irons would be great performers. On the other hand I feel like they sort of date the truck and take away some of the scaleness. However, I'm struggling to find tires with a scale appearing open tread design. I crawl on mostly mud and trees. The Rc4wd MTZ is a possiblity though it seems to tight down the center. Baja Claws are very nice as well but a friend has them on a similar rig and I don't want to copy his build.
Old 11-11-2016, 05:47 AM   #13
Check out the 1.7 x2 Irocks. They look great on a 1.9 wheel and go like hell in your type conditions. That's my personal go to small tire. . Let me know. There is a fellow club member that has 5 new he isn't using he's now a big tire guy lol.....
Old 11-11-2016, 11:49 AM   #14
distinctive pd's Avatar
The OG 1.9 TSL PL Swampers look good under a Yota body as well
distinctive pd is offline   Reply With Quote
Old 11-11-2016, 12:21 PM   #15
Absolutely! The original sticky tire and still favored by many.
Old 11-11-2016, 01:14 PM   #16
MWRCA'er
Mnster's Avatar
Thanks for all the suggestions.
The 1.7"s are fantastic tires I use the Boggers on my Sami build. The only problem I have is that the carcass gets really rounded when stretched over a 1.9.
The Proline Swamper didn't work that well for me in a 2.2 on a different build. Though it may have been a foam setup issue it just seemed like the carcass was to thin and the lugs just bent over. I think I'll likely probably settle for them down the road once the build is finished. When performance takes lead over making a clean new truck.
I just ordered a set of 1.9 MTZ's We'll see how they fit the build. I liked the narrow appearance. A friend of mine also had them on his 1:1 4runner for a while so they are etched in my mind as Toyota tires. Performance likely won't be super great but I can swap them out to something else later.
Old 11-14-2016, 04:16 PM   #17
MWRCA'er
Mnster's Avatar
Old 11-21-2016, 11:28 PM   #18
MWRCA'er
Mnster's Avatar
Unfortunately I'm still waiting on tower to ship my ar40 axles. So today I decided to try to take a shot in the dark at making a chassis for this thing.
Eventually. I ended up with something that sort of resembles a Toyota pickup frame. I'll admit the bends are not the same as a Toyota but at least it's a good straight platform to start from.
Old 11-22-2016, 03:59 AM   #19
Fab skills, love these builds with a ton of fabrication and engineering. Will be fun to see it come along!
joe122 is offline   Reply With Quote
Old 11-22-2016, 12:15 PM   #20
frame looks great and dont let the MTZs fool you, they are actually pretty narley tire! One of favorites actually, just wish they made them in a taller 1.5 version
1986 Toyota IFS build - Similar Threads
GCM's 1986 M1009 Blazer Build Generis Vaterra Ascender 134 01-14-2016 09:09 PM
banshee build (ifs and more ;) dieseldee Axial Wraith 0 02-17-2014 12:07 PM
IFS axial build red_zook General Scale Talk 6 04-28-2012 08:43 AM
1986 suzuki samurai build neightfrog 1.9 Scale Rigs 32 06-12-2009 02:16 PM
1986-95 Toyota bodies Biscuit Paint and Body 12 04-06-2008 01:22 PM
