12-19-2017, 05:19 PM | #41 |
Rock Crawler Join Date: Dec 2014 Location: Union Bridge, MD
| Re: Matzilla Crew Cab F-350
Forgot pic Sent from my XT1585 using Tapatalk |
12-19-2017, 05:34 PM | #42 |
I wanna be Dave Join Date: Dec 2009 Location: Outside DC
Unfortunately length is the most important factor! Here is another of my setups. The second picture is at ride height. Sent from my iPhone using Tapatalk |
12-19-2017, 05:37 PM | #43 |
| Re: Matzilla Crew Cab F-350 |
12-19-2017, 05:38 PM | #44 |
12-19-2017, 05:41 PM | #45 |
12-19-2017, 05:43 PM | #46 |
It shouldn’t unless there’s binding. Sent from my iPhone using Tapatalk |
12-19-2017, 05:46 PM | #47 |
12-19-2017, 05:47 PM | #48 |
What’s longer? Your drag link or panhard? Post some pics in varying angles of how the servo is mounted. Sent from my iPhone using Tapatalk |
12-19-2017, 05:50 PM | #49 | |
| Re: Matzilla Crew Cab F-350 Quote:
Sent from my XT1585 using Tapatalk | |
12-21-2017, 06:59 PM | #50 |
Mount is mocked up with styrene. But here are shots from different angles. Both drag link and panhard are the same length. They seem to be parallel compressed and extended. They are not parallel with the axle though. How will this hurt? Sent from my XT1585 using Tapatalk |
12-21-2017, 07:17 PM | #51 |
I can move servo up but will have to extend the mount. No biggie. It has to be done. This will make them as close to parallel with the axle as I can get. Sent from my XT1585 using Tapatalk |
12-22-2017, 06:48 AM | #52 |
It's looking better! Ultimately it would be best if your panhard mounted to the chassis from the front and the the servo horn was flipped to put the drag link closer to the steering link, but once you do that, it may put the drag a little too far forward. You can always put a spacer on the chassis side panhard mount to bring that further forward. How is it working? For new guys reading...they may not know what bump steer is. Bump steer is when the suspension cycles and the up and down motion makes the steering knuckles turn on their own. Hence you hit a bump, and the axle steers even when the servo isn't moving. As long as it cycles smooth or you have very little bump steer, you're there. Edit, I just noticed the one picture with the servo moved forward. That could get you far enough forward (with a new mount) and then just remount the panhard in front of the mount. It's all about problem solving. Last edited by Bulldog; 12-22-2017 at 06:54 AM. |
12-22-2017, 07:37 AM | #53 | |
12-22-2017, 07:39 AM | #54 |
War department! I love it! Het a starbucks and you’ll be fine! Sent from my iPhone using Tapatalk |
12-22-2017, 08:07 AM | #55 |
Operation "as perfect as I can get it steering" complete. Anodizing of the aluminum panhard mount was tricky. It required pulling the cap off a Sharpie. Sent from my XT1585 using Tapatalk |
12-22-2017, 08:37 AM | #56 |
Servo extension brackets with the same anodizing method Sent from my XT1585 using Tapatalk |
12-22-2017, 11:27 AM | #57 |
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
Wait till I tell Vickie what you said!!! LOL Looking good so far Cary! When I'm setting up a front end like your doing on a new build I don't get to hung up with the steering/pan hard touching the axle when I push straight down. If I can flex one side at a time and it doesn't touch I call it good. If you think about it, how many times when your crawling does your suspension cycle straight down all the way to the bottom? Since this rig, for you is as much or more about looks than function (I think) don't get to rapped up in trying to get it perfect. Just my thoughts. Give Vickie and the kids a hug for Marcia and I! Ernie If we make it east this fall I'm going to give you some lessons on using the Safety Silv 56. Your to the point in your skills that it would help you and Rhett a lot! Last edited by CODYBOY; 12-22-2017 at 11:31 AM. |
12-22-2017, 11:34 AM | #58 |
Oh, and hope you're having fun at the mall!!! Ernie |
12-22-2017, 11:45 AM | #59 | |
12-22-2017, 11:55 AM | #60 | |
Lou's looks work. We are in route to the kids for Xmas, so talk with you this evening. Ernie | |
Matzilla Crew Cab F-350 Angus - Similar Threads | ||||
Crew Cab F-350 | bigdodge88 | 1.9 Scale Rigs | 44 | 11-12-2009 09:00 AM |
AI F-350 Crew Cab Two | ALTERED IMAGE | 2.2 Scale Rigs | 4 | 04-28-2009 07:15 AM |
f-350 crew cab | super pig | General Crawlers | 1 | 09-22-2008 12:18 PM |
f-350 crew cab help | super pig | General Scale Talk | 4 | 09-20-2008 08:27 AM |
