03-16-2019, 08:37 PM | #21 |
Quarry Creeper Join Date: Jan 2008 Location: Antioch
| Re: Unimog U1300L DOKA Rally Edition
I've had my eye on these bodies for some time now. Do they seem durable, what type of material are the made from, is it one molded piece or separate parts glued together? I know that's a lot of questions, thanks.
03-16-2019, 11:28 PM | #22 |
RCC Addict Join Date: Feb 2008 Location: Tekin, ID
| Re: Unimog U1300L DOKA Rally Edition They are CNC router cut from ABS sheet. Seems pretty sturdy and is all glued together. Should anything break or separate, it will be easy to repair.
03-17-2019, 02:00 AM | #23 |
Quarry Creeper Join Date: Sep 2018 Location: Denmark
It's porn on wheels!!
03-17-2019, 02:00 AM | #24 |
03-23-2019, 12:22 PM | #25 |
Quarry Creeper Join Date: Nov 2007 Location: Sacramento
Amazing build! I would love to see those wheels filled up with Locked Up RC scale hardware.
03-24-2019, 10:44 PM | #26 |
Newbie Join Date: Feb 2016 Location: Vancouver
Love the hinge you built for the body mount! Is the 3d file for that part available to download anywhere? |
03-26-2019, 04:11 PM | #27 |
Quarry Creeper Join Date: Nov 2018 Location: Mexico, Guadalajara
Awesome build please keep this thread updated, I am planning to build a Unimog based on BP custom chassis who is compatible with SCX10 geometry Initially I wanted the same Unimog body than yours but then I realize that I don't like the big rear cab so I ordered just the front cab to build the back later , Now I am debating between which axles should I choose for my project, Initially I order the VP Currie Rockjock axles just because I really like the design, but that was an impulsive purchase and now I realize that build the rockjock axles cost the same than portals axles . I know that the real Unimog has portal axles but in your opinion: how do they fit using the Unimog body? do you think that the Unimog body sits too high using portal axles? do you think that portals perform better than ArR44 or rockjock axles? this is the body and chassis that I choose |
03-27-2019, 11:30 AM | #28 | |||
| Re: Unimog U1300L DOKA Rally Edition Quote:
The body sits at a good height for me, I'm going for a modified look anyways and this truck has quite a bit of travel. Ideally these axles would work best on a Vanquish chassis or something that is high clearance for portal axles. Performance I can't comment on since I haven't driven them yet, but the added axle clearance is definitely welcome and the lower gear reduction in the portal boxes will reduce torque twist. For a Unimog build I feel they are a must, otherwise the spirit of the truck is not quite what it should be. | |||
08-07-2019, 02:45 PM | #29 |
This build was shelved to finish up the K-55 Rally Truck and now that it's done, I can get back on this one! We printed some mounts to fit the bed to the SCX10-II chassis and it feels like it is on there really solid! Next up will be some spring loaded latches to hold the cab down. Already printed part of that system to get the correct height, now it's on to getting the latch system done. Then we just need to knock out an interior, the rear cage and spare tire holder, fuel tanks and a few LEDs and I'll finally be able to drive it! |
08-07-2019, 04:24 PM | #30 |
Pebble Pounder Join Date: Aug 2015 Location: Newfoundland
Each one of your builds is a classic! Great work and an inspiration to us all! Thank you for the detailed build threads! Sent from my iPad using Tapatalk |
08-08-2019, 05:13 AM | #31 |
Newbie Join Date: Jun 2019 Location: Andover, United kingdom
I'm really enjoying this build. The cab looks so much better than axials standard unimog body. I'm looking forward to seeing some action shots when this is finished.
08-12-2019, 03:25 PM | #32 |
Printed up all the parts for this roll bar setup last week, cleaned them up and painted over the weekend and just mounted it in the Mog. Also did up a filler panel for the huge hole in the bed. Working on the interior now! |
08-15-2019, 03:17 PM | #33 |
Drivers' side fuel tank is done and mounted! We're going to have a 1,000mi + range! |
04-16-2020, 03:54 PM | #34 |
Rock Crawler Join Date: Jun 2013 Location: Portugal
full of neat ideas...
04-16-2020, 05:08 PM | #35 |
Quarry Creeper Join Date: May 2013 Location: no-water-no-trees-country
Did your body come assembled??? I have one like that in a box - about two point five billion pieces. No instructions - LOL Need to get back to it, seeing your awesome rig! |
04-21-2020, 12:45 PM | #36 |
| Re: Unimog U1300L DOKA Rally Edition Yep, it was pre-assembled! I have dismantled this truck and started over though, it is now on a VS4-10 Ultra chassis.
06-14-2020, 01:22 AM | #37 |
Newbie Join Date: Aug 2019 Location: London
I have this exact body on a TRX4! It is fantastic. I didn't build mine but mine has cantilever rear shocks so the bed can stay flat. Proline Grunts look brilliant on it. |
08-16-2020, 10:21 AM | #38 |
Quarry Creeper Join Date: Apr 2013 Location: San Diego
How did I miss this. Very nice looking unimog!
Unimog U1300L DOKA Rally Edition - Similar Threads | ||||
The DSPro Unimog U1300L Class 2, Milex Cab announcement! | rbgerrish | 1.9 Scale Rigs | 99 | 03-20-2023 09:06 PM |
H2Micr0's Unimog U1300L | H2Micr0 | 1.9 Scale Rigs | 29 | 05-15-2017 12:47 AM |
3d printed Unimog U1300L Hard body project | TeamJammy | Axial SCX-10 | 7 | 04-30-2015 09:01 PM |
First build: Unimog U1300l Camper | b8point6 | 1.9 Scale Rigs | 10 | 02-09-2015 09:56 PM |
