07-23-2012, 10:02 AM | #41 |
Rock Crawler Join Date: Nov 2011 Location: Paradise, ca
| Re: 1.9 to 2.2 axial scx10 work in progress
Well shoot me a text some time i lost your number when i dropped my phone amongest other numbers
08-07-2012, 12:52 AM | #42 |
Quarry Creeper Join Date: Dec 2011 Location: Willows
Scx10, venom creeper 1:1 chevy c10 4wd 1969 chevy step side pickup, 8 inch lift with 37/14.5/15s locked 14 bolt rear, posied dana 44 front |
08-07-2012, 08:47 AM | #43 |
Your creeper knuckles look to be angled way down your c hubs are on wrong sides or at least one isnt correct one
08-07-2012, 11:15 AM | #44 |
My whole axle is angled and i know my right sides off, im just too lazy to fix it
08-07-2012, 10:08 PM | #45 |
It will crawl beter if you rock axle back wards so knuckles are level or tipped slightly backwards
08-08-2012, 09:48 AM | #46 |
I need to, but i was thinking real driveline angles
08-08-2012, 11:17 AM | #47 |
Bring it by sometime next week and ill take a look it shouldnt be that bad of a angle with axle rolled back
08-08-2012, 11:20 PM | #48 |
Its at a pretty funky angle right now.
08-08-2012, 11:23 PM | #49 |
Sounds like you got something weird bring it by next week and let me see
08-09-2012, 03:19 AM | #50 |
Oh i know what i need to do, i just need to play with some stuff on it.
08-18-2012, 04:13 AM | #51 |
Well i FINALLY have a simple light setup. 15 leds, 2 headlights, 1 backup light, 12 undercarriage lights.
08-19-2012, 11:03 AM | #52 |
I got a new bumper and some rock sliders, the rock sliders are awesome, but i dont think i can use the bumper. My tires rub WAY too much, and i did a home made FREE CMS mod to it because i had to
08-19-2012, 04:58 PM | #53 |
Pebble Pounder Join Date: May 2012 Location: Satsuma
I did the Radio shack boxs on my sliders to. They are great to me. On the esc box i drilled a hole in the top and cut venilation holes in the bottom with the drimel. I bolted a traxxas vxl fan to the top to keep it cool. you may want to do that if you with the boxs. |
08-20-2012, 11:06 AM | #54 |
I was wanting to try and waterproof it, or just go with a different brushless system all together. I had to stop every 15 to 20 minutes to let my motor cool.
08-20-2012, 12:36 PM | #55 |
As long as its not getting to 160 or above your fine
08-22-2012, 12:09 AM | #56 |
While showing a friend how much bump steer i have in my kitchen, on the linoleum floor, the screw that holds the heim joint to the rod (both the joint and rod are aluminum) forking broke, and it broke more in the heim joint so i have to get another aluminum one to match the other side, and figure out how to reduce my bump steer because i dont want to 3 link it.
08-27-2012, 01:38 PM | #57 |
I have decided to 3 link the front using different length links and using the axial 4 link truss still. It goes more to the driver side to clear the drag and panhard bar links, then my next step is to lift it more using the vp shock relocators for the back and the strc ones for the front. And im doing rhe 3 link correctly by using the aluminum y and aluminum and steel links. I hope it works good. It looks cool. Ill post pics in a little bit.
08-27-2012, 02:05 PM | #58 |
Ok so here is what i have so far, my losi mini lower link bent into a z for my drag link, and then the rest is of my cms setup and 3 link setup, im thinking of flipping my 3 link bar because its contacting my driveline Last edited by minicrawlerguy530; 08-27-2012 at 02:07 PM. |
08-28-2012, 12:43 AM | #59 |
So i ditched the cms setup for now. I was too lazy to fab up some mounting plates, but i was playing with different setups and realized how the heim joints need to be positioned, so its either that or buy a setup which i might need to do that because of my super powerful servo. But the offset 3 link bar doesnt hinder anything and i have the vp shock relocators are upside down so as to lift the rig, they are only in front which leved it out instead of having an inch of difference. So now its time to find a 9 volt battery connector to hook my lights up to
09-03-2012, 01:29 PM | #60 |
So i went out and tested my boggers. X2 compound is better than x3 Last edited by minicrawlerguy530; 11-19-2012 at 08:44 PM. |
Tags |
1.9s, 2.2s, axial, scaler, scx10 |
1.9 to 2.2 axial scx10 work in progress - Similar Threads | ||||
SCX10 2.2 Work in Progress | alexchen86 | Axial SCX-10 | 3 | 06-20-2010 07:41 PM |
work in progress | dub599 | Paint and Body | 32 | 12-19-2009 11:38 AM |
work in progress | uberalles | Losi Mini-Rock Crawler | 14 | 10-17-2008 05:43 PM |
Work In Progress | BrockGrimes | 2.2 Scale Rigs | 12 | 04-26-2007 05:21 PM |
work in progress very,very slow progress! | rednekcrwlr | Tamiya Clod Buster | 6 | 12-18-2006 09:48 PM |
