11-15-2017, 01:58 PM | #41 |
RCC Addict Join Date: Nov 2014 Location: Nowhere
| Re: Fr8cture's Toyzuki C3 No. The Toyzuki Chassis are technically made for the SCX10 / SCX10 II, what fr8cture is doing here is kind of like a "Wroncho", putting AR60/Wraith axles underneath a ladder frame like the SCX10/SCX10 II uses.
11-15-2017, 02:36 PM | #42 |
| Re: Fr8cture's Toyzuki C3 |
11-16-2017, 01:45 PM | #43 |
11-16-2017, 02:31 PM | #44 |
| Re: Fr8cture's Toyzuki C3 There is one post about it but mostly just in the toyzuki fan page fb group you can see some builds.
11-16-2017, 04:26 PM | #45 | |
RCC Addict Join Date: Nov 2016 Location: 1972 born Christian, Chinese.
| Re: Fr8cture's Toyzuki C3 Quote:
Dear fr8cture, good evening it would be great if you would able to post us some videos about your Wraithzuki in action. Thank you so much Sir Sent from my iPad using Tapatalk | |
11-16-2017, 04:56 PM | #46 | |
RCC Addict Join Date: Aug 2005 Location: SoCal
There's a few good videos of Toyzuki running his V3 at the latest CWRCRC comp on facebook. | |
01-11-2018, 10:38 AM | #47 |
Rock Crawler Join Date: Jun 2017 Location: Land of burning couches
Did this ever get finished?
01-11-2018, 05:49 PM | #48 |
01-11-2018, 06:00 PM | #49 |
Performance 3D solutions sent me a new revised skid. This one moves the t-case forward along with a better fit around the t-case. I also asked him to add some holes to bolt down a battery tray Ty from Tekin helped me get a old FXR replaced so thats what will be going in here along with a castle bec 2.0 (15a). I got it mostly soldered up just need to do the motor. I'm trying to figure out how I want to wire everything up with the 2 servos. Ideally I want to run 2 rx bypasses one for each servo since the bec has 2 outputs but I'm not sure if they both supply the same amount or if when overloaded power drains over to the second output. I contacted castle about it but have not heard back yet. That brings it up to date to what I've done so far. Last edited by fr8cture; 01-11-2018 at 06:03 PM. |
01-11-2018, 08:09 PM | #50 |
Rock Crawler Join Date: May 2012 Location: Minneapolis
Looks good Eric! Be mindful of that trans to tcase shaft looks like an sdi. Adam had those break all the time on scalers last year. I’ve done quite a bit of 2 servo wiring (even 3). On one rig I used the old castle bec pro. When I took it apart to waterproof I fount that the two leads from the bec are just parallel circuits off the same terminals on the board. So if this version of the bec is the same you can either use or just cut off the other set of wires. On the supersix I used one set to power the front servo and the other to power the two rear servos. All with savox 1230 servos. Those are power hungry and in that heavy rig I never had a problem with the servos browning out. Sent from my iPhone using Tapatalk |
01-11-2018, 10:52 PM | #51 | |
Your setup sounds exactly like what I want to do and eliminate the bec from taking two spots on my rx. I would just like Castle to confirm it. It's been 3 or 4 days I figured I would have had a reply by now. | |
01-29-2018, 05:28 PM | #52 |
Another small update. It's slow moving as I'm waiting for the body to be modified by a friend hopefully next week sometime. I got a good deal from tower on some vanquish VXDs. Unfortunate situation they are in but made for some good deals. I was able to switch both axles to VXDs. I also switched over to some kyosho velvets turned down with rod end caps a friend made me along with dlux spring cups and dravtech springs. A big mess of wires in the front I just got a wire crimper so I'll have it cleaned up. |
01-29-2018, 05:38 PM | #53 |
Rock Crawler Join Date: Dec 2012 Location: Utah
Looks wicked dude! like like!
01-29-2018, 05:53 PM | #54 |
Blue shocks? Come on! Other than that this thing is looking filthy! Love it! |
01-29-2018, 05:57 PM | #55 |
Didn’t see any knuckle weights on your V3 ? Are you using wheel weights? Thank you
01-29-2018, 05:58 PM | #56 |
02-08-2018, 05:14 PM | #57 |
Sneak peek. Last edited by fr8cture; 02-08-2018 at 05:56 PM. |
02-08-2018, 06:44 PM | #58 |
What spring rate are you using from Dravtech? I’ve been playing with medium rate, but the weight bias on my truggy is so forward that it just bottoms up front even without a battery in the rig. Back seems ok with the medium rate - at least on the bench. Just wondering if I order firms if that’ll even be enough.
02-08-2018, 08:21 PM | #59 | |
02-17-2018, 12:23 AM | #60 |
Body is finished. It should be back to me sometime this week. Here is a few shots. Last edited by fr8cture; 02-18-2018 at 07:53 AM. |
Fr8cture's Toyzuki C3 - Similar Threads | ||||
Fr8cture's JK8 #2 w/ Toyzuki V2 chassis | fr8cture | 1.9 Scale Rigs | 92 | 06-01-2020 09:29 PM |
Fr8cture's JK8 | fr8cture | 1.9 Scale Rigs | 196 | 05-03-2017 06:40 PM |
Fr8cture's Trail finder 2 w/ Mojave II | fr8cture | RC4WD Trail Finder 2 | 74 | 10-26-2016 04:22 PM |
Fr8cture's RC4WD Gelande II Cruiser | fr8cture | 1.9 Scale Rigs | 19 | 03-09-2016 12:29 AM |
Fr8cture's 2dr Jk | fr8cture | 1.9 Scale Rigs | 127 | 01-05-2016 06:01 PM |
