10-02-2017, 01:07 AM | #1 |
| Fr8cture's Toyzuki C3
I've never been much of a 2.2 guy but when Ben released this chassis I decided to build one. Here is a run down of the parts. -Toyzuki V3 chassis kit -SSD Diamond axle housings -Dlux textured G10 U4 trusses -Dlux V2 Knuckles CF upper Arm/Aluminum center and lower arms -Dravtech SMW 15° link mounts -Vanquish scale knuckles -Vanquish scale C-Hubs -Vanquish steering links -Vanquish knuckle bushings -Vanquish servo clamps -Vanquish aluminum SLW brake rotors -Vanquish VXDs F/R -Vanquish rear bumper mount -Axial HD stock/underdrive -Performance 3D solution t-case cover, front tray and rear cross brace -SSD transmission gears -Holmes Hobbies one piece extended trans output -Scaler Fab Comp series front bumper -Kyosho Velvet shocks -BottomsUpRc Hawk 2.2 beadlocks -Pitbull 2.2 Rock Beast XORs -Crawler Innovations 6.5 soft/med foams -Titanium links by Nerby149 -MIP HD Driveline Driveshafts -SDI driveshaft for top shaft Electronics -Tekin FXR -Team Brood V2 Custom -Protek 170tbl -Protek 370tbl -Spektrum SR410 -Castle 2.0 BEC 15a -Gearhead RX bypass x2 Here is some progress pics. Assembled front axle and dravtech shocks. Outside picture to really show off the textured G10. Simple mock up with all thread links. I used stock wraith length lowers. As you can see here I am doing a 4 Link and axle mounted servo with the front motor mount. This is the first mock up proving it will work. The link was bent straightened and rebent multiple times by hand so it doesn't look the greatest. Last edited by fr8cture; 01-22-2018 at 12:08 AM. |
10-02-2017, 07:19 AM | #2 |
Rock Crawler Join Date: Apr 2015 Location: Paola, ks
| Re: Fr8cture's Toyzuki C3
What kind of body are you planning Sent from my SM-N920V using Tapatalk |
10-02-2017, 12:28 PM | #3 |
Installation of the transfer case. I used the one from my V1 in a few pics while waiting for my new one. As you can see I had to modify the skid to fit it. Ben said he was gonna fix this. I also had to lay the skid on its side so the top shaft doesn't hit the motor. It is a very tight fit with a SDI shaft. I think it's the only shaft that will work with this setup unless Ben figures something else out. I am the first person to test this setup. I used SSD transmission gears, Holmes Hobbies single piece extended output and Performance 3D Solutions gear cover. I got a few servo horns from Air Wild for this project recommend by Dlux it sets up the steering geometry well and gives me as much frame clearance as possible. (I am gonna have to clearance the frame some) Here is the wheel and tire setup. BottomsUpRc 2.2 Hawk wheels in orange/gunmetal, SuperShafty Brass bearing rotors, Pitbull 2.2 Rock Beast XORs, Crawler Innovations 5.5 soft/med foams. Last edited by fr8cture; 10-02-2017 at 12:31 PM. |
10-02-2017, 12:32 PM | #4 |
| Re: Fr8cture's Toyzuki C3 |
10-02-2017, 01:10 PM | #5 |
You like your orange, huh? Those orange BURC wheels are sick! And this build is going to be bad ass. Hopefully you post video when you're finished.
10-02-2017, 01:17 PM | #6 |
10-03-2017, 11:09 AM | #7 |
Quarry Creeper Join Date: Jul 2013 Location: Maple Ridge B.C. Canada
Hey looks really good. Love the Toyzuki, can’t wait to see this finished!!
10-03-2017, 09:59 PM | #8 |
You know depending on how much you need to clearance th frame you could just limit your shocks that much. Looks like you have more than enough travel in the front. Just a thought
10-04-2017, 01:37 PM | #9 |
| Re: Fr8cture's Toyzuki C3 Yeah it clears when flexing its just under compression. Not sure how I would only limit it under compression. Maybe some sort of bump stop in the center of the axle.
10-05-2017, 05:37 PM | #10 |
Here is a little update. I had Nerby (149 rc worx) build me some titanium links. He did the front and rear lowera/uppers. They turned out great he does good work. Also as you can see I ordered the new MIP HD Driveline shafts for the TRX-4. Luckily they fit my rig perfectly. Replacing the SSD I originally planned to use. I mounted up my wheels and tires along with a new SSD front bumper which I'm thinking about replacing with a Scaler Fab pro series bumper. That's it for now. Last edited by fr8cture; 01-22-2018 at 12:07 AM. |
10-06-2017, 06:26 AM | #11 |
Front links look great! No worries about them twisting around at all? I've had mixed experiences with shaped links.
10-06-2017, 09:10 AM | #12 |
10-08-2017, 03:39 PM | #13 |
Another update. I got a package from brood today. My V2 custom motor. I asked Eddie to find me a orange sticker for the can and he pulled through with this cool old school sticker. Specs: V2 End bell and can sprint edge brushes Hard MR springs Type R Flat Wire 7.5mm comm armature ground polished and dyed drill balance Mounted in the chassis. There is much more top shaft clearance than I had with the ROC412. Here is the body I picked up for it. I may or may not keep this body. I haven't decided. I also picked up a SSD bumper that will probably end up on a different project. I had to clearance the bed for the shock hoops. I may have a friend dovetail and bob this bed for me. I think it needs it. Last edited by fr8cture; 10-08-2017 at 03:44 PM. |
10-08-2017, 07:42 PM | #14 |
That looks bad ass. Sent from my SM-N910V using Tapatalk |
10-08-2017, 09:06 PM | #15 |
I wanna be Dave Join Date: Dec 2009 Location: Outside DC
Is this the same thing as an axial crawler? I love all the orange. Only true diehards decorate their crawlers for Halloween. Nice car. How fast does it go? I could keep going all night! BD |
10-08-2017, 09:54 PM | #16 | |
| Re: Fr8cture's Toyzuki C3 Quote:
I am preparing the green as we speak. | |
10-09-2017, 08:14 AM | #17 |
RCC Addict Join Date: Aug 2008 Location: Paulina
Very nice build! Those XORs look nice and wide and I think pair that body great for a C3 build. Don't think I've seen a dovetailed LC70 yet. What's your WB at? |
10-09-2017, 09:35 AM | #18 |
I can't get over how bad ass this thing looks. I love the stance. I personally think dovetailing it will ruin the look. I also don't think it's needed for performance since the tires stick out so far beyond the body. What color are you going to paint it? Orange? |
10-09-2017, 10:53 AM | #19 | |
Gunmetal I think. | |
10-09-2017, 10:55 AM | #20 |
Fr8cture's Toyzuki C3 - Similar Threads | ||||
Fr8cture's JK8 #2 w/ Toyzuki V2 chassis | fr8cture | 1.9 Scale Rigs | 92 | 06-01-2020 09:29 PM |
Fr8cture's JK8 | fr8cture | 1.9 Scale Rigs | 196 | 05-03-2017 06:40 PM |
Fr8cture's Trail finder 2 w/ Mojave II | fr8cture | RC4WD Trail Finder 2 | 74 | 10-26-2016 04:22 PM |
Fr8cture's RC4WD Gelande II Cruiser | fr8cture | 1.9 Scale Rigs | 19 | 03-09-2016 12:29 AM |
Fr8cture's 2dr Jk | fr8cture | 1.9 Scale Rigs | 127 | 01-05-2016 06:01 PM |
