05-13-2009, 09:27 PM | #201 |
Quarry Creeper Join Date: May 2008 Location: Federal Way/Tacoma
| Here's what I started with.... |
05-13-2009, 09:29 PM | #202 |
05-13-2009, 09:30 PM | #203 |
I need to take more so I can show the rear and the front...ect Looks off to me but you can't see it in the pic, but I'll take more I'm having issues with Last edited by m&mkrawler; 05-13-2009 at 09:33 PM. |
05-13-2009, 09:38 PM | #204 |
Quarry Creeper Join Date: Jul 2008 Location: Chattanooga
05-14-2009, 06:57 AM | #205 |
you might want to check your thread options...sounds like you're in a different thread view mode.... |
05-14-2009, 08:28 AM | #206 |
I see the pictures from previous posts just fine, except the ones that say they are removed by photobucket. Where is this thread options stuff at?
05-14-2009, 08:55 AM | #207 |
let me try again but I can see them right now...the edit options in you CP should be a section on viewing threads...also...if your on the thread...at the top...it says stuff like Thread Tools...ect... I'll post one right now and see if you can see it or something is goin on... |
05-14-2009, 08:57 AM | #208 |
05-14-2009, 03:44 PM | #209 |
I can see that one just fine. |
05-15-2009, 11:02 AM | #210 |
| OK....heres a couple more.... I had to extend the rear upper links because of my driveshaft yoke connection was lower than my lower links... I'll have a picture of that in a little bit...you should be able to see it better... |
05-15-2009, 11:06 AM | #211 |
| Heres a couple of the front...still have to work out the kinks.... |
05-18-2009, 03:24 PM | #212 |
| Heres how I mounted the electronics.... |
05-18-2009, 03:27 PM | #213 |
05-18-2009, 03:31 PM | #214 |
| what do you think about \how I mounted everything....? |
05-18-2009, 06:27 PM | #215 | |
Quarry Creeper Join Date: Aug 2007 Location: Morrison Crawlerado
Your build looks good... have you driven it yet? I really like those RC4WD wheels. Quote:
Then you can move your servo behind the motor like this: It keeps the COG nice and low... especially since you're running a full-size servo like me. I'd be curious to see how those shocks work mounted with the caps down... seems like they might bind. I tried mine like that and ended up cutting the top of the caps off and adding traxxas rod ends to smooth everything out. You got any pictures with your lid on? Look forward to your progress! Let us know how it crawls! Last edited by MtnBkr; 05-18-2009 at 06:32 PM. | |
05-18-2009, 06:58 PM | #216 |
wow....yours looks trick....I thought when I ordered it...I thought I got the AXIAL Tranny plate w/dig...? I'm always ordering wrong....can I drill the plate still...? |
05-18-2009, 07:52 PM | #217 | |
I can get you the dimensions if you need them. | |
05-19-2009, 01:08 AM | #218 |
Pebble Pounder Join Date: May 2008 Location: Bellevue
How much ground clearance do you have at the skid? Looks like those shocks could be limited quite a bit. For example I am running 4" losi shocks, limited about 3/4". This makes the chassis much more predictable and stable. |
05-19-2009, 01:38 PM | #219 | |
I'm sitting at 2.75 at this moment....??...good...?? | |
05-19-2009, 02:31 PM | #220 |
