01-12-2009, 05:01 PM | #21 | |
I wanna be Dave Join Date: Aug 2007 Location: santa monica
I'm on expert with axials but thats the first thing I thought of when I saw the pictures. flatten the axles first. output shaft should be only slightly tilted up from horizontal. this will shorten your uppers, which is a good thing. also just take it in your hand and move the suspension to check for anything that might be binding up or hitting. you can usually tell what is binding, if something is, in this way. you could also unbolt one thing at a time to see how it affects the suspension travel. first the two upper links of one axle, replace and try the two shocks, etc. to try and find the one thing that is binding it up. good luck. I know how frustrating it can be. I went through something similar with my first truck. Once I figured it out it was very rewarding (both the driving and having been able to sort it myself, with the help of this board). good luck. | |
01-12-2009, 05:12 PM | #22 |
Rock Stacker Join Date: Nov 2005 Location: Street
| How does that look for pinion angle? |
01-12-2009, 05:12 PM | #23 |
+1 on loosening the zip ties on the electronics mounts.
01-12-2009, 05:17 PM | #24 |
Rock Crawler Join Date: Jul 2008 Location: Chula Vista
I would also suggest going with Losi Shocks. I was running a stock setup and I wish I bought the Losi's sooner than I did. Where the shocks attach to the chassis what are you using right now? I would reocmmend going with some washers and Fuel Tubing this will allow your shocks to move around a bit. I am no expert just my .02
01-12-2009, 05:17 PM | #25 |
Rock Stacker Join Date: May 2008 Location: lake mary
01-12-2009, 05:23 PM | #26 |
RCC Addict Join Date: Feb 2006 Location: ccxc
why the bent rod ends on the uppers? I'd ditch those
01-12-2009, 05:27 PM | #27 |
01-12-2009, 05:32 PM | #28 |
Quarry Creeper Join Date: Sep 2008 Location: !! MOAB !!
I think you are on the right path. |
01-12-2009, 05:33 PM | #29 |
Rock Stacker Join Date: Nov 2008 Location: orange county
Okay, as I see it from your pictures is a few things I would address: Rear suspension; The four link is good, I like the use of the servo mount. However, it is not long enough to get the correct pinion angle. The plate can still be used, you just need to move the mounting holes closer to the outside(tires). The link ends should be mounted to the underside of the plate to help with the torque twist. You need to shorten up the links and mount them in one of the three holes provided in the chassis to get back to the beginning. The upper link length is what is going to help level out your pinion angle. In addition, remove the spacer between the upper link and the frame, you can use that somewhere else later. Take your receiver off of the rear until you get all of your suspension flex figured out, then mount it back on it. Take the spacer off of the rear shock and start over with that. The front is pretty good, get some soft/extra soft springs up front and work with that. It will change a lot right away and then you can tweek it from there to your liking. It is a game of tune, test and back to tuning again. It gets a little old, but once you see some changes it is way worth it. That is a good start, keep us posted! |
01-12-2009, 05:43 PM | #30 |
Quarry Creeper Join Date: Dec 2008 Location: other side of the track,the bad side
those rear upper links give you a horriable axel angle, If I were you I would go back to a stock setup, run 1 inch of fuel line in your shock, get super soft springs this is called a 50/50 shock setup weight your wheels, use 2 1/2 packs of the fronts and 2 packs in the rear. sometimes when people make there own parts they just make things worse.doing these couple of things you wil notice a difference in your truck |
01-12-2009, 05:51 PM | #31 |
Newbie Join Date: Nov 2008 Location: Frankfort
I run a high pinion angle on the rear and has worked well for me, I moved it small amounts at a time and it ended up working for my rig (slingshot) I think that setup on a rock crawler comes 2nd to driver I have worked with setups for weeks and found with my rig that a soft spring in the rear and a VERY heavy oil in the rear shocks brings traction and weight to the front when on the rocks and in a bind. A loose truck to me is sloppy to drive and with any speed is out of control looking with any driver. |
01-12-2009, 05:52 PM | #32 |
Quarry Creeper Join Date: Dec 2007 Location: At the Gates
| thats much better. You need to Remove your shocks and do the following: -use 1/2" of fuel tubing under the piston to limit your ride height -Use the firmest (stock/blue) springs in the rear -Use the softest (red) springs in the front -Properly fill and bleed your shocks with 30weight -securely install your shock caps, being carefull not to cross thread thats the first thing you need to do to fix your suspension and it will cost less than ten bucks |
01-12-2009, 05:55 PM | #33 | |
One thing about those orange spacers. I can't tell for sure, but are you using conical washers between the spacer and the rod end or is the spacer and nut right up against the rod end faces? If those are right against the rod end face...the rod end can't pivot and the axle end rod ends are doing all the movement for the uppers. I would also try and triangulate the links more. On the uppers...if you make the spacer as small as possible at the frame (if you do in fact need them at all), and then if you can push the mounts at the axle end closer together, it will triangulate them more. Same for the lowers...if you swap the spacer and link location on the axle mount, and put the spacer inward, this would spread the lowers apart more at the axle. If you can, even try and pull the lower end of the shock inside the axle mount and put the link on the outside where you have the shock now. Not sure if that'll cause clearance issues though...so that's just a thought. It really doesn't look like the zip ties are what's keeping anything from twisting. The uppers are not really moving around that much anyway. Last edited by Offroader5; 01-12-2009 at 05:58 PM. | |
01-12-2009, 05:55 PM | #34 |
I ran the same upper links in my old stock chassis they work fine. the mounting hole you have in the chassis should be a little higher to achive the proper link seperation. Link seperation is the key to torque twist. You do not need to spread the link out on the servo plate but i would get a plate that has the holes lined up straight. yours are off by a couple mm. Yes you can always go back to the stock upper mount holes,but you will have more torque twist and more pinion angle change during flex. With the uppers the same length as the lowers the pinion angle will not change during flex. Here is a shot of my current rear setup. Last edited by moabax; 01-12-2009 at 05:58 PM. |
01-12-2009, 06:04 PM | #35 |
Rock Stacker Join Date: Feb 2008 Location: Shingle Springs, CA
This thread is a PERFECT example of why I'm proud to be a member here!
01-12-2009, 06:35 PM | #36 |
01-12-2009, 07:11 PM | #37 |
Rock Crawler Join Date: Nov 2008 Location: Roseville,Ca
Like BILLYGOAT said make sure the zip ties holding those plates to your upper links are not tight that will bind it up for sure.
01-12-2009, 08:05 PM | #38 |
Pebble Pounder Join Date: Jan 2007 Location: H D
the rear upper links limit you up travel so you need to ether go under the mount or but one that makes the ball cup verticle..... it wont articulate up that well the way you have them set now
01-12-2009, 08:15 PM | #39 |
Pebble Pounder Join Date: Jul 2008 Location: bedrock
try using tcs 4 link plate in rear and jato turnbuckles to fine adjust your pinion angleto about 2 deg.,you can still use the orange spacers on the chassis side to.
01-12-2009, 08:27 PM | #40 | |
http://rcpcrawlers.com/product.php?p...&cat=29&page=1 | |
