08-02-2010, 06:45 PM | #1 |
Rock Crawler Join Date: May 2009 Location: Idaho Falls, ID.
| fastback owners show them here
post up pic's of your new fastback here with the spec's to go with it!
08-02-2010, 06:56 PM | #2 |
ok here it is Juan's underground fastback chassis white rovers w/Eritex Delrin wheels Underdrive rear gears HH 35t handwound 16t pinion rooster crawler ESC 3s lipo vp dig (on the way) 3/8's fatty delrin lower links 5/16 delrin upper links (close to equal length) |
08-02-2010, 07:22 PM | #3 |
Rock Crawler Join Date: Jul 2009 Location: boise
ill play, build thread Thomas' Underground Crawlers Fastback the first black and white fastback she has never seen rocks, i just got it today |
08-03-2010, 06:26 AM | #4 |
I wanna be Dave Join Date: Dec 2009 Location: Lady Lake, Fl
| billj's Fastback
just got the chassis last night, has not even seen real rocks. Underground Crawlers Fastback white rovers on wheelworks m887's nova dd foams fxr 3S lipo tekin 45 machine wound (getting a handwound soon) VP dig w/ hitec 645 Vp razors on rear super 300's hitec 7950th castle bec 7v home made delrin bent links 5/16 Losi 4" shocks w/ cap mod hardened alum tranny gears MIP driveshafts Gunnar hex pins and driveshaft pins hd ring and pinions fr/rear underdrive Axial straight axels Axial high clear knuckles strc clockable c's Losi clamp-on wide hexes (front) drilled out for 300's racers edge pro servo horn LD BTA Crawler Inovations servo guard (modified) and the list goes on and on and on....... one more thing " thanks Juan!!" Edit: Sedonas on front 35t handwound JP Warrior Finally got it onto some rocks!! Last edited by billj; 09-03-2010 at 06:09 PM. |
08-03-2010, 07:06 AM | #5 |
Rock Crawler Join Date: Jan 2009 Location: crawlorado
here my pimpness....sporty rig right now.....till i get my hurtz
08-03-2010, 07:21 AM | #6 |
| VP DH Pro comps (front) with Sedonas VP SLW V3 (rear) with Rovers Nova's Ark foams Super 300’s HD front gears Under drive rear gears MIP center shafts Steel tranny gears (make unknown) VP Hurtz dig VP Razors Axial BTA Axial plastic rear lock outs Axial straight axles Racers Edge Pro servo horn Hitec 7950th steering servo Hitec 5445b dig servo Losi comp shocks (50 wt front, 45 right rear, 60 left rear) VP 4 link\battery tray cut for bta clearance VP 4 link plate on rear, cut down for clearance on equal length upper links Holmes Hobbies Handwound 35t motor Mamba Max (old school) Castle BEC at 7.4v Delrin lower links Delrin rear upper links Aluminum front upper links |
08-03-2010, 07:37 AM | #7 | |
08-03-2010, 04:55 PM | #8 |
08-04-2010, 10:54 PM | #9 |
| How's the rooster holding up to the 3s? I thought it can only handle 2s.
08-08-2010, 09:01 PM | #10 |
Pebble Pounder Join Date: Jul 2010 Location: St. George
Specs that I know: -Underground Crawler Fastback Chassis (of course) -Rovers on all corners -HR aluminum wheels -Underdrive Rear Bevel Gear -Metal front and rear drive shafts -HR Alum tranny case with all metal gears -Mamba Max ESC -Integy 35T motor -VP Dig -Losi Shocks -Axial BTA Steering -Hitec HSR-5990TG steering sevo -Yeah Racing 3s 1000 mah -Castle BEC -Custom rear axle razrs - thx Tom Last edited by swollen goat; 08-08-2010 at 09:09 PM. Reason: accedintally hit enter |
08-08-2010, 10:01 PM | #11 |
08-09-2010, 05:00 PM | #12 |
08-09-2010, 05:35 PM | #13 |
you have to run an external lipo cut off but other then that they will run just fine on 3s.......ive seen a bunch of people doing it for a good amount of time.....no issues
08-09-2010, 05:36 PM | #14 |
08-09-2010, 05:48 PM | #15 |
updated pic for "ghostrider"vanquish revolvers/dh comps hot bodies sedonas ugc fastback chassis mamba max 3s 35t v11 integy motor mip cvds drive shafts mip front cvd's modded ace 1015 servo for steering hitec 645mg for dig vp hurtz dig delrin links ccbec 10amp Last edited by flapjack; 08-10-2010 at 12:49 PM. |
08-09-2010, 05:51 PM | #16 |
08-09-2010, 05:51 PM | #17 |
looks like your hood spacer broke or something, cool shot though.
08-09-2010, 05:53 PM | #18 |
nope it didnt break....im using a pintle chain plate to give my 3s a little more clearance
08-09-2010, 09:26 PM | #19 |
08-09-2010, 09:50 PM | #20 |
btw the info came from novak.........and not the first time its come back to me as info people got from novak....but i agree with dickyt about the bec as well...usually think of those as a standard item as well
