04-05-2011, 11:36 PM | #41 |
I found that by the time I had everything in place, there was no room for actual pushrods, just rod ends butted up against each other. Also, by keeping the assembly high and as close to the axle centerline as possible, you'll have no need for bent anything...it all should fit around the shock with no problem. I hope to start on my version real soon, so I'll keep you updated if you'd like. |
04-05-2011, 11:44 PM | #42 | |
Tossin' Salad Join Date: Jun 2010 Location: Petaluma
Im sure my pics will be clear once I post them in or around the weekend. For sure, keep me in the loop on what you come up with. Casey | |
04-05-2011, 11:53 PM | #43 |
Quarry Creeper Join Date: Sep 2009 Location: Vancouver,Canada
i installed mine tubes by dremeling the inside of a axle and that's it just screwed 3mm screw through axial hub and attached to the tube did needed to do any drilling what so ever. Worked for me so far just mine 0.02 c. |
04-06-2011, 12:11 AM | #44 |
Chris, your ideas and your pic have given me an idea for the drag link and a better mounting method for the push rods. This is what I will make to start with. |
04-06-2011, 01:38 AM | #45 |
Quarry Creeper Join Date: Jun 2009 Location: Way down under!!!
Casey, To extend Du..ude's concept of fuel tube to remove the slope? You could, since you are using Ti rod, slot the rod or introduce a keyway and dowel or pin the rod into a fixed axis of movement. If you slot it, you could use long threaded pin (CR01 Drive pin say) and have two points of location. "Keyed', you could have a shallow, wide key and limit rotation but still get good purchase. Or mill a flat on the rod and introduce a wide, flat-ended grub screw to hold it all in place.... Can sketch for you if you need (but I reckon your gettin' it hey?) Last edited by stewbaru; 04-06-2011 at 01:43 AM. |
04-06-2011, 01:42 AM | #46 |
Well, I will not take that route at first...my design will be a bit different than Duuuuude's. His push rods are much shorter than mine, and they are much closer to the axis of travel of the tie rod. My push rods will extend down and away...so, I do not know where I would even want to put any keyway yet. It is all just academic at this point. I will have a clear understanding of where to go after this weekend of fab. Casey |
04-06-2011, 01:45 AM | #47 |
. Either way, I look forward to the next rendering. . |
04-06-2011, 01:51 AM | #48 |
In fact, this is most likely the angle at which the tie rod will be sitting. The push rods will extend down at a steep angle to the high steer arms of the knuckles. |
04-27-2011, 12:36 AM | #49 |
Rock Stacker Join Date: Dec 2010 Location: Cranbrook BC
will the tubes fit in the rear with lockouts and not the Cs?
04-27-2011, 02:06 AM | #50 |
Try to Bend it Join Date: Aug 2009 Location: Perth Australia
Yes they can be used in both axles.
05-29-2011, 11:37 AM | #51 |
Rock Crawler Join Date: Jun 2008 Location: Grants Pass OREGON!
Lookin tits Casey,gonna wait on a bta set up til you make this one available. Was pondering on the Ti link rotating,maybe marked degree splines? Or hex so you can set the bta link to a specified degree marking on the delrin slide block? May be retarted ideas I dunno. |
05-30-2011, 04:19 AM | #52 | |
05-31-2011, 09:21 PM | #53 |
Rock Stacker Join Date: May 2011 Location: Salt Lake City
| newb question
What is the clocking i am getting ready to install my beef toobs and just want to make sure i do it the right way the first time!
05-31-2011, 09:28 PM | #54 |
Ex Nor-CalRCRC slave Join Date: Dec 2008 Location: San Mateo, CA.
If you have to ask, then you better stick with the stock install. |
05-31-2011, 09:35 PM | #55 | |
Casey | |
05-31-2011, 09:36 PM | #56 |
06-02-2011, 03:14 AM | #57 |
RCC Addict Join Date: Dec 2010 Location: middle,tn
hey man i just bought the 8* vp chubs and knuckles..will i have any issues if i order 2sets..also im still running stock cvd's ..will you help me with this issue because i really need to get these toobs to help finish my build i will b buying 300's later down the road but funds are tight right now...thanks please help |
06-02-2011, 03:15 AM | #58 | |
Should be no issue mate. Casey | |
06-02-2011, 11:03 AM | #59 |
RCC Addict Join Date: Jun 2005 Location: Prosser
Just got my order of Toobs, and are the tapped holes done by machine? They dont line up with eachother at all and makes the top part of the case open and the bottom closed. Looks like someone eyeballed drilling them. I can get pics if need be...
06-02-2011, 11:43 AM | #60 | |
Are you doing a standard install, or clocking? Using plactic C's or alum? Generally, the C surrounds the ends of the housing and holds it in place. If the holes were so far off, then it would be pretty tough to bolt the C in, the holes would not line up. Where is the spreading of the housings occuring, right next to the C? If you have a 5/64" drill bit, or a piece of rod that will fit in the holes, post up a pic of that, so we can see how far off they are. I usually check over each toob before shipping, but a few times I'm in a hurry, so I don't inspect each hole thouroghly. Last edited by gunnar; 06-02-2011 at 12:28 PM. | |
