Thread: Delrin Tube *NOW TAKING ORDERS*
Old 03-16-2012, 11:42 PM   #1
Chris_The_Battery_Man's Avatar
Default Delrin Tube *NOW TAKING ORDERS*
So I came up with this idea a while back to adapt full length XR universals into AX10 axles. Made a set for some axles that had the splines melted into them, and ended up selling the chubs on a truck that I sold. See the below link for the splined set.
Well, that truck shifted directions, and I am selling the axles to a buddy. I needed to complete the tubes so he could finish the axles. This is what I came up with. They aren't too hard to make. A little time consuming on a manual lathe. But pretty straight forward.
I am still thinking of buying a set of chubs to use for molding the splines, and making a jig. But this is much easier to make at the moment.
How many of you good folks would want something like this? They're made to cut the end off where the stock chub slides on, and then they go in to the edge as you can see in the pic. You then can put XR knuckles, chubs, and stock length shafts on the front giving you more steering, wider track width, and stronger inner axles.
EDIT
There have been alot of people PM'ing me to get in on the first batch. I will close the doors on this batch this evening(3-23-2012) sometime. Prices and purchase info is in the below link
http://www.rccrawler.com/forum/axles...ml#post3645410
CreationFab Resurrects La Licorne Fatale!
Chris_The_Battery_Man is offline   Reply With Quote
Old 03-17-2012, 12:14 AM   #2
Default Re: Delrin Tube Interest?!!?!?!?
Hey Chris,
I think this is a winner ! Especially for those just starting out or even for people trying to up grade what they without killing the wallet and or purse.
DRV KRAWLER is offline   Reply With Quote
Old 03-17-2012, 12:20 AM   #3
ScaleFreak93's Avatar
I'm liking the idea as well! Now make some for the xr lockouts and rear shafts and I'm sold
ScaleFreak93 is offline   Reply With Quote
Old 03-17-2012, 12:24 AM   #4
I like it. This mod has crossed my thoughts a time or two. I'm down for it.
obebaldone1 is offline   Reply With Quote
Old 03-17-2012, 07:11 AM   #5
I love this i would buy these in a heart beat plus there lighter than the Long Beef tubes
2006Shelby is offline   Reply With Quote
Old 03-17-2012, 08:03 AM   #6
Proverbial threadkiller
Trubble's Avatar
Default Once again, information that would've been a little more helpful to me YESTERDAY!
Had this been available as little as a week ago, I'da probably jumped all over these things. But my XL Beef Tubes just got here yesterday.
I'd really like to see this idea come to fruition, just in case I get a Honcho for a trail truck and need a rustproof solution. Keep us posted if you decide to continue with this project.
Trubble is offline   Reply With Quote
Old 03-17-2012, 09:25 AM   #7
Delrin Tube Interest?!!?!?!? >> YES
TotoRax is offline   Reply With Quote
Old 03-17-2012, 09:42 AM   #8
Very interested!
OKJeepin is offline   Reply With Quote
Old 03-17-2012, 10:56 AM   #9
Location: You will never find a more wretched hive of scum and villainy
count me in
DeweyCJ5 is offline   Reply With Quote
Old 03-17-2012, 12:22 PM   #10
Ex Nor-CalRCRC slave
gunnar's Avatar
I like the one peice design, clean. Looks like a great lightweight alternative, just gotta be careful not to crank down the chub screws and strip the holes. Hope they sell well!
gunnar is offline   Reply With Quote
Old 03-17-2012, 01:33 PM   #11
i'm in for a set
ax10 is offline   Reply With Quote
Old 03-17-2012, 06:15 PM   #12
Here's a couple more pics I took.
I might try to get down the process and make a small run of em. Been pondering it, and am thinking of a pair for $25.
Old 03-17-2012, 07:39 PM   #13
TSK
Shelf queen
TSK's Avatar
That's looking slick buddy
You have my "go ahead"
TSK is offline   Reply With Quote
Old 03-18-2012, 09:09 AM   #14
I'd be up for a front and rear set for my 4ws truck.
sdcrawls is offline   Reply With Quote
Old 03-18-2012, 10:35 AM   #15
That was a direction that I was thinking of heading last month. I have been trying to find a machine shop that would machine the splines for me. I would buy a couple sets.
doors4u is offline   Reply With Quote
Old 03-18-2012, 12:12 PM   #16
I would be very interested in a set.
agbracing is offline   Reply With Quote
Old 03-18-2012, 07:05 PM   #17
Location: Taylors Falls just hanging with the MNRCRC crew.
Those are awesone, I'd like some.
Stormin2u is offline   Reply With Quote
Old 03-20-2012, 01:16 AM   #18
So I think I will do a small run of these to test the waters. PM me if you're actually interested. Might do a pre-sale.
I will probably have 2 versions.
Non-splined: $25 a pair
Splined:$35 a pair
Going to order some supplies and do some measuring now. Stay tuned folks.
Old 03-20-2012, 10:46 AM   #19
I would also like to note that these will not "LOOK" like a machine shop did them. I am not a machine shop. I do have pretty good size manual metal lathe, but am not a pro. Every piece that I send out will be test fitted before shipping to ensure complete functionality. I will be doing extensive quality control. But note these are hand made. They should look a bit better than the pics shown however. The splined versions will definitely look like plastic that has seen heat at the splines.
Old 03-20-2012, 12:28 PM   #20
TSK
Shelf queen
TSK's Avatar
I'll take 2 pair of the unsplined version
I see soooo many possibilities with these tubes.
- Good alernative to standard beef tubes, especially if you already run knuckle weights. These would allow you to take the weight out of the axle housing and put them father outat the corners which utilizes the weight more effectively.
- Lightweight wide rear axle option (WK shafts) for guys who already have long beef tubes up front. Non using steel tubes in the rear axle will minimize F/R bais change.
- Wide axle setups for FOFF's without fattenening them up.
Thought i'd make mention since Chris hasn't made note of it yet.
With the unsplined version, you will either need to drill the XR chub to make it bolt up like an AX chub (countersunk screws will prevent loss of steering angle), or run additional screws (in the very corners of the XR clock slots) to prevent the chub from roating on the tube.
Use of the splined version will prevent this from happening
Delrin Tube *NOW TAKING ORDERS* - Similar Threads
delrin axle tube do the produce them yet rccrawler77 RC4WD Bully 36 02-13-2011 10:38 AM
Another delrin/acetal tube question gordieb Colorado 7 02-26-2010 10:29 AM
Delrin tube? theslowguy Tools, and Procedures 21 10-02-2009 09:44 PM
