02-20-2012, 02:06 PM | #1 |
Pebble Pounder Join Date: Jan 2012 Location: vincennes
| question on new drag link and tie rod
this weekend was my first comp and i broke my servo. i ordered a cs-170 today and i dont think the stock steering linkage is going to work. i do not want to run bta. my knuckles are still stock. i had a pm from a guy with what axial rods i needed to make my own steering linkage but have since deleted it. does anyone know what length rods are needed? or can recommend a good but on the cheap steering linkage replacement? my servo is centered on the axle
02-20-2012, 02:13 PM | #2 |
| Re: question on new drag link and tie rod
I prefer the Traxxas Revo rod end with All Thread method, then you can make them whatever length you need.
02-20-2012, 03:08 PM | #3 |
| Re: question on new drag link and tie rod |
02-20-2012, 03:11 PM | #4 |
I think it's 3:32. If you run a search you'll be sure to find several "threads" |
02-21-2012, 03:22 AM | #5 |
anyone have a link to revo rod end set screws? i cannot find them anywhere
02-21-2012, 07:40 AM | #6 | |
| Re: question on new drag link and tie rod Quote:
How To: Make your own links | |
02-21-2012, 08:55 AM | #7 | |
didn't mean to mislead you, I'm currently on my cell phone so searching is difficult... | |
02-21-2012, 10:24 AM | #8 |
RCC Addict Join Date: Jun 2009 Location: Salmon Arm BC
definitely 8/32 all thread.. for tubing i found that my tie rod and lower links bent pretty easy with aluminum tubing so try to find some stainless steel tubing. i've been switching my lower links and steering links to SS tubing and using alum tubing for the upper links because i bought lots of it and it doesnt take the abuse that the lowers do. i will making up some links probably today for my ax10.
02-21-2012, 08:59 PM | #9 | |
Quarry Creeper Join Date: Oct 2010 Location: The "Nanny" State
02-21-2012, 09:23 PM | #10 |
Well right now its still the stock plastic linkage where the drag link attaches to the tie rod. I don't think its rigid enough to hold up to all the torque. And the stock servo horn that I have right now should fit the hobbico servo pinion(?). Also when I get the servo do I need to do anything to it or just hook it up and go? Sent from my i777 using Tapatalk. |
02-21-2012, 10:10 PM | #11 | |
Other than that, you should be able to just hook it up and go. Good luck! | |
02-22-2012, 03:01 AM | #12 |
Yeah I have a bec set at 6 volts. I just didn't know if I needed to grease anything or not Sent from my i777 using Tapatalk. |
02-22-2012, 05:29 AM | #13 |
RCC Addict Join Date: Nov 2009 Location: cleveland,Tn
if i was you i would pm r2j and get him to make you a set of solid stainless steering links that are 4mm with the revo ends for like $12 i think im running his steering links and uppers and lowers on my wraith and ax10 and the are awesome.
02-22-2012, 12:57 PM | #14 |
definitely upgrade the links get rid of the plastic crap.. it cant hold up to the abuse that we put our crawlers through with the truck turned on and turning the wheels you can see the plastic linkage bend even on flat ground.. make/buy one for the drag link too..
02-22-2012, 02:31 PM | #15 |
i asked r2j and he said that he doesnt make them anymore. but theres a vendor on there that is so i gotta wait till i get my servo and and some rod ends
03-08-2012, 06:46 PM | #16 |
Rock Stacker Join Date: Mar 2012 Location: Salt Lake City
Got my replacement drag link and tie rod on order so can't say for sure, but for the price these look pretty darn good? Axial Wraith Aluminum Steering Linkage Blue TopCad 23003 |
03-08-2012, 07:02 PM | #17 |
That's for the wraith. I don't know if it'll fit the ax10 Sent from my i777 using Tapatalk. |
03-08-2012, 07:12 PM | #18 | |
Rock Crawler Join Date: Jun 2011 Location: San Diego
03-08-2012, 08:26 PM | #19 |
Rock Crawler Join Date: Nov 2009 Location: poteau
as for suspension links you shouldn't need any. the gatekeeper chassis you have comes with good links. for the steering you can just make some. the 8-32 allthread, revo rod ends, and something to sleeve the allthread with works good. or you can buy axial 106mm link (tie rod) and i think its a 73mm link for the drag link
question on new drag link and tie rod - Similar Threads | ||||
Help with drag link and tie rod. | 07trd4x4 | Axial Wraith | 19 | 01-12-2012 04:28 PM |
new vanquish tie rod and drag link | bighemitex | Axial Wraith | 21 | 10-23-2011 05:56 PM |
Double drag link no tie rod? | day215 | General Crawlers | 10 | 07-02-2011 09:11 PM |
Tie Rod/Drag Link Setup? | Hyperlite33 | Axial AX-10 Scorpion | 4 | 06-24-2008 03:58 PM |
