05-20-2012, 07:00 PM | #1 |
Rock Stacker Join Date: Apr 2011 Location: seattle
| Narrower motor plate for Fastback II
Anyone know if there's a motor plate out there that isn't as wide as stock? I'd like to fit some body panels to my FBII build (alllllmoooost done!) but it looks like it would be a real pain in the buttocks with the plate sticking out past the motor.
05-20-2012, 11:33 PM | #2 |
| Re: Narrower motor plate for Fastback II
Negative. How would the motor mount if the plate was narrower? Just pepp one of the many FB builds for inspiration on how o mount you panels
05-21-2012, 06:02 AM | #3 |
It can only be so small. Either way, the motor is still going to hang out. You can get the motor mounted up, scribe a line on the plate along the side of the can that sticks out, then tear it all down and cut it off. |
05-21-2012, 06:18 AM | #4 |
RCC Addict Join Date: Jan 2010 Location: Dallas
If I'm understanding you I had similar issues as I'm running a smaller spur with a smaller pinion to try and tuck everything in a bit. Then I took a dremel to my plate to grind off some.
05-21-2012, 09:44 AM | #5 | |
Quarry Creeper Join Date: Jul 2009 Location: Dublin,Ireland-Cluj,Romania
| Re: Narrower motor plate for Fastback II Quote:
also have a FII,and have panel on the motor side,i use some plastic,that is called VERALITE,which is 0,3 0,5 0,7 thicker,and you can heat the panel and it will be shaped around the motor | |
05-21-2012, 10:25 AM | #6 |
I used a belt sander and notched the bottom corner. I run my motor/transmission in a more forward position than the regular drill option, so I had to get a bit more aggressive with how much material I took off. |
05-21-2012, 10:29 AM | #7 |
I was going to suggest an angle grinder.
05-21-2012, 10:45 AM | #8 | |
Also, photobucket FTL. | |
05-21-2012, 10:49 AM | #9 |
Thanks for the replies folks - I can do basic metal work but am thinking if I try to attack the plate I may end up bending it all up. Perhaps I'll give it a shot anyway! Heating the plastic to form around the motor is an interesting idea too. Back to the drawing board, after a few test runs last night I'm considering different motor / gearing anyway so it looks like this build is (of course) not quite as close to "done" as I had hoped |
05-21-2012, 11:07 AM | #10 |
Ex Nor-CalRCRC slave Join Date: Dec 2008 Location: San Mateo, CA.
Yea, just use some kind of grinder to remove most of the material, then a file to clean it up, sandpaper the edges to finish. For this build, the motor plate was the least of my worries! Stock EEM plate: This helped a bit: |
05-21-2012, 06:21 PM | #11 |
| Re: Narrower motor plate for Fastback II That was such a great build thread but some A**hole decided to delete it |
06-09-2012, 08:42 PM | #12 |
Rock Stacker Join Date: Jan 2012 Location: asheville
this is the one i got... AX/SCX Motor Plate NO DIG here's what it looks like on my rig.. looks like sanding or grinding the stock plate works too though. i always like when parts are black with raw areas too, looks trick. |
Narrower motor plate for Fastback II - Similar Threads | ||||
130 motor, motor plate | thesnake505 | Losi Micro-Rock Crawler | 19 | 01-26-2012 02:58 PM |
Motor Plate - Front Mounted Motor | bsn | Axial AX-10 Scorpion | 7 | 03-18-2011 04:49 PM |
AX10 Motor Plate/Motor Mounting Problems | md7989 | Electronics | 8 | 11-25-2010 01:30 PM |
fastback motor options | keithgemmill | Axial AX-10 Scorpion | 9 | 09-11-2010 07:33 PM |
