01-30-2013, 08:07 PM | #301 | |
I wanna be Dave Join Date: Aug 2008 Location: Having fun again...
| Re: Krawl's shafty "The Villian S" Quote:
and you are quite correct. you can also use the traxxas short length shock shafts with egressor bodies to achieve the same overall length. my shocks are actually 3.125"eye to eye with a med size axial shock rod end. the belly sits at @ 3.125" fully drooped and exactly 2" fully compressed. it does this with with only about a 2* pinion angle (and as equally important castor) change throughout the cycle. it also has very minimal axle steer which keeps the vehicle tracking correctly and also helps to settle the vehicle while trailing a high side rear tire. the reason i shortened the bodies was to gain down travel.. the usable travel is now well within the parameters of my 4 link geo regardless of droop or compression. i also dont need to limit my shocks any longer because they are actually only able to "stroke" what is needed (instead of limiting internally and externally) those are the reasons i went this route but a properly limited 3.5" shock will give you very similar results. | |
01-30-2013, 08:17 PM | #302 |
I wanna be Dave Join Date: Oct 2007 Location: 801
I figured that's why you shortened the bodies. The one downfall to an internally limited 3.5" shock would be the lack of compression due to the longer body IMO. Maybe I missed it, but what is the belly clearance at ride? Last edited by Chaotic Crawlers; 01-30-2013 at 08:28 PM. |
01-30-2013, 08:32 PM | #303 |
I think the traxxas short shafts with EGRESSor shock bodies are still 3.5" unless I'm using the wrong shafts. I'm using the ones from he 2660 setand still measuired out to 3.5" for some reason. could be the rod ends i usede though. For most, shortening the shock body isn't the problem, it's finding the right length shaft. i have spent some time at the LHS rying o find an ot of the bag 3" shock but have had no luck. And 3" losi's are expensoive to build. |
01-30-2013, 09:11 PM | #304 | |
The chassis was designed around a standard 3.5" shock, then given adjustability. And tsk, I think the idea with the short shaft is you shorten the body to accommodate it..Also the egressed bodied shocks are not really budget by any means. Belly at ride is 2.8-2.9 ish | |
01-30-2013, 09:12 PM | #305 |
Aren't the shock arms adjustable?
01-30-2013, 09:54 PM | #306 |
Quarry Creeper Join Date: Dec 2009 Location: aurora
I am pretty sure that's why he wrote in the previous post and I quote " that's why the shock arms are adjustable" sent from Team Angry Birds |
01-30-2013, 10:01 PM | #307 |
| Re: Krawl's shafty "The Villian S" |
01-31-2013, 07:15 PM | #308 |
RCC Addict Join Date: Sep 2006 Location: Depew
I can't wait any longer! I need one now!!!!!
01-31-2013, 08:25 PM | #309 |
Rock Crawler Join Date: Aug 2012 Location: Etowah
I need one yesterday.... I need to have the cash ready for the release, btw, when is this gonna happen?
01-31-2013, 10:17 PM | #310 |
Rock Crawler Join Date: Mar 2008 Location: amherst, ny
02-01-2013, 02:26 AM | #311 |
X3 sent from Team Angry Birds |
02-01-2013, 02:29 AM | #312 |
I thought this was a single chassis build... |
02-01-2013, 07:00 AM | #313 |
Rock Crawler Join Date: Aug 2011 Location: Perth west oz
i hope not. jeremy is such a teaser.....
02-02-2013, 09:04 AM | #314 |
Quarry Creeper Join Date: Apr 2009 Location: Lincoln
Do you have some more info about the motor for this truck? I need a new 1 too! Thanks Ty
02-02-2013, 04:27 PM | #315 |
Rock Stacker Join Date: Feb 2012 Location: Modesto
wow looks amazing keep us updated and keep up the great work. and sorry if i missed it but is this going to be a production chassis? -steven |
02-02-2013, 05:15 PM | #316 |
I wanna be Dave Join Date: Jan 2008 Location: GrandRapids, MILITIAGAN
Yes, so here says. He's teasing us right now.
02-02-2013, 08:42 PM | #317 | ||
This will be a production chassis but it will not be budget by any means.. There are plenty of those already. The timeframe for release is still undetermined. My team drivers and trusted acquaintances will get the first chassis made to give honest feed back and help to show you guys different build perspectives.. Quote:
I don't want to misinform anyone with the high tech goodness | ||
02-05-2013, 10:38 AM | #318 |
I wanna be Dave Join Date: Apr 2007 Location: Arlington, Washington
The quick and skinny on the motor... .040 Conflux can FB12 Magnets Type HHK-T 30t arm, ground polished dyed....epoxy balanced. Standup Brushes with Super stiff springs. Endbell features lightweight spring posts, screws, and heatsink elimination screws along with the new lightweight alloy timing ring. Some other tricks and such... Later EddieO |
02-05-2013, 04:35 PM | #319 |
RCC Addict Join Date: Feb 2008 Location: Crawlerado
^ I'll take 2 please. |
02-06-2013, 12:25 PM | #320 |
I will take one of the chassis as soon as its available. PayPal is ready and has your name in the send to line. Very very nice work. Please keep up the perfection sent from Team Angry Birds |
Tags |
molly whop |
Krawl's shafty "The Villian S" - Similar Threads | ||||
Krawl's "THE NEXT LEVEL" SUPER AGENT #1 | krawlfreak | Superclass Crawlers | 323 | 03-13-2014 02:08 PM |
Krawl's "SECRET AGENT" turned "DOUBLE AGENT" | krawlfreak | Axial XR10 | 1361 | 12-05-2013 08:25 AM |
Krawl's RC4WD Build Off Entry " The Overlandy" | krawlfreak | 1.9 Scale Rigs | 51 | 04-17-2013 05:47 PM |
4xFord's "Super Villian" Team Y-Town build | 4xFord | Axial XR10 | 174 | 02-01-2012 02:01 PM |
"TWIN FREAK" Super Shafty First run video | v84x4 | Videos! | 7 | 03-28-2011 06:40 AM |
