03-31-2013, 02:39 PM | #1 |
RCC Addict Join Date: Oct 2009 Location: San Francisco
| CW Speedy Sporty build
Well its time I do a speedy sporty build thread Till I can get photos worked out leme cut to the details. Front axle thanks to TSK: Chris axle tubes with stock XR chubs and knuckles. XR uni's Axial OD gears Brass expanding inserts (these are nice!) Sintered lockers Transmission thanks to me: custom 7075 motor plate to replace the hacked up junky 6061 it has now we all know 7075 makes everything better Not sure on motor yet Rear axle thanks to me: Brass inserts Rear plastic lockouts axial straight shafts UD gears Sintered lockers Chassis thanks to TSK. It is the one he ran at the Shootout so i hope it does me good Revo shocks Delrin lower links VP SLW .7's thanks to TCS donating them to the shootout Rovers Photos soon to come once I figure out the new Google Picasa |
03-31-2013, 03:42 PM | #2 |
I wanna be Dave Join Date: Sep 2009 Location: Eastcoast CANADA
| Re: CW Speedy Sporty build
Pics or it didn't happen..... Rob |
03-31-2013, 04:05 PM | #3 |
| Re: CW Speedy Sporty build |
03-31-2013, 04:59 PM | #4 |
Damn that's a good looking chassis!
03-31-2013, 07:29 PM | #5 |
I wanna be Dave Join Date: Dec 2008 Location: anderson
looks like a killer start |
04-01-2013, 03:21 PM | #6 |
Thanks guys, it is a pretty dang sweet chassis. Ok I made progress today I found my 7980 servo Jokes aside i did strap some Revo shocks to the rig. They are the hard ano ones so they should hold up NICE! Now onto the obvious pics! I may have to do a rod end cap mod because of a lack of clearance. Oh well nothing to hard The chassis has more of a 65/35 setup but well see what I can do. I always liked how an custom 60/40 chassis crawled that I had made up years ago |
04-01-2013, 04:39 PM | #7 |
Rock Crawler Join Date: Mar 2008 Location: amherst, ny
Nice start. I like what i see
04-01-2013, 07:26 PM | #8 |
Rock Crawler Join Date: Aug 2010 Location: Socal
Looking good man!!! I like how the shock and link holes are angled. I have a similar idea I have been throwing around in my head. Maybe I'll get some time to get it drawn and cut out.
04-01-2013, 08:50 PM | #9 | |
| Re: CW Speedy Sporty build Quote:
Lil more progress: Put together the rear axle with UD gears, plastic lockouts and a Underground Crawlers D-link. I love that lil hunk of 5052 aluminum Determined I will need to do some kind of modification with a good old dremel to the stock Revo caps or do a rod end mod on them to get the desired results. Oh well that will add a little more length to the shocks which wouldn't be a bad thing overall. Its just im racing the clock so any delays is a big problem | |
04-01-2013, 09:26 PM | #10 |
Rock Crawler Join Date: Feb 2006 Location: Cutting Comms
Haven't seen anyone using Revo shocks in a while. What are you planning on doing for springs? I've got a set of Revos that I've tried to use on a few occasions but even the softest spring options still seemed too stiff.
04-01-2013, 10:08 PM | #11 |
| Re: CW Speedy Sporty build Funny that's also where I got my inspiration. Juan had a good idea with that feature. I loved my UGC chassis.
04-01-2013, 10:46 PM | #12 |
Yeah the "arc'd" link and shock positions are something I figured would help minimize the ride height, pinion angle & caster changes while making suspension changes. That said, the chassis worked fine at the Shootout, but I didn't have the droop setup quite right. Main reason why I ditched it is so I can gain some experience with tuning with the huge input the Chaotic crew can provide me. I have a basic understanding of what will do what, but I just never spent the time to tune anything. As far as the Revo shocks. First thing to do is drill the piston holes larger to open up the vavling. Those shocks are valved immensely slow since they are designed for use on a heavy truck with pushrod suspension. The cantilever/rocker arms on those trucks have like a 3:1 leverage ratio on the shocks. For springs, I think you could use shortened Losi comp shock springs in a Mini T fashion. Otherwise I would probably try replacing the bladder with an prong at the base of the cap threads and run a Mini T internally. I don't see cap modding them very easy as the cap is pretty tapered throughout. I think I would try running them spaced out from the chassis (more vertical fronm the front view) to gain the kearance as the chassis is only like 55mm wide. All that said, I think I would still try running that chassis again in droop. Just need really soft internal springs. I was running medium TCS droop spellings at the Shootout and they were just a bit too stiff. I had super soft TCS droop springs somewhere but could't find them. |
04-01-2013, 10:52 PM | #13 |
I never posted body off pics of this chassis in my Masami Special thread, but I'll post them here. This was with EGRESSor shocks. I didn't like the way it felt and I did have time to tune them so I went to droop. In this pic you can see that the chassis is fairly narrow. It's on wraith axlesnin these pics, which mount the links and shocks just outside of the AX axle tabs. So if Cal was to run the shocks outboard of the link tabs he could easily spa e the shock off the chassis and still keep a decent shock angle. |
04-02-2013, 12:05 AM | #14 | |
That said tonight its time to hobble out to the belt sander and work a lil magic... oh well nothing like precision sanding engineering | |
04-02-2013, 03:29 AM | #15 |
Its a HARDKNOCKZ Life... Join Date: Feb 2011 Location: Southern Kali...
The SP is a super cool chassis & I'm bummed I didn't get it together before handing her down to the bearded builder. Chassis has a TON of potential but honestly Cal...not sure Revo shocks would be the way I'd go. I planned on running Big Bores limited down with internal springs for that semi setup. I love the base & low slung design of the SP & hope you & Steve get some tune time with it. If I wasn't a loyal Chaotic driver...I'd DEFINITELY be running THE 5D SUCKER PUNCH! J.D. |
04-02-2013, 08:48 PM | #16 | |
After some late night texting with Travis I decided to space the revo shocks out vs doing any late night "precision" sanding. That said tomorrow if I am lucky ill get some lower links made for this guy | |
04-02-2013, 08:56 PM | #17 | |
J.D. | |
04-02-2013, 09:00 PM | #18 | |
That said I want to have a LITTLE more than 30 seconds drive time before I get to the competition. Speaking of will you be there? | |
04-02-2013, 11:48 PM | #19 | |
04-02-2013, 11:50 PM | #20 |
CW Speedy Sporty build - Similar Threads | ||||
WaCkAdOoDlE Sporty build | Chris_The_Battery_Man | Axial AX-10 Scorpion | 55 | 02-19-2015 11:46 PM |
Comp Sporty Build | redneckrampage | Axial AX-10 Scorpion | 5 | 06-04-2013 02:00 PM |
PhantomRS10's '13 Sporty build | PhantomRS10 | Axial AX-10 Scorpion | 12 | 03-20-2013 12:59 PM |
1st build - Sporty | AWDPete | Axial AX-10 Scorpion | 28 | 10-02-2012 04:45 PM |
