10-27-2013, 03:32 PM | #1 |
Newbie Join Date: Oct 2013 Location: st.clair
| Axial AX10 Scorpion Rookie build
To start off, I bought the crawler for $85 running with a few issues. After a weekend of crawling and working on it every 20 minutes I took it home and tore it down. It has the Novak Brushless Crawler motor, Savox 250oz servo(another ordered for rear). I have a lot of parts ordered to get it back together, just getting a little at a time. Will post pics as soon as I figure out how on my phone. |
10-27-2013, 06:54 PM | #2 |
RCC Addict Join Date: May 2013 Location: York, PA
| Re: Axial AX10 Scorpion Rookie build
Welcome to the board. Are you planning to comp this rig? Rear steer isn't allowed in the sportsman class. If it's for fun, awesome. If you plan to comp it, better get used to driving it without rear steer. Looking forward to some pics. |
12-09-2013, 01:09 PM | #3 |
This is my Ax10 when I started |
12-09-2013, 01:14 PM | #4 |
These are all from the tear down/build process |
12-09-2013, 01:16 PM | #5 |
Have my rear steer servo, 6ch transmitter, alloy horns and lipos ordered. If any of you guys have a 1/10 body that'll work on my truck, let me know.
12-09-2013, 04:35 PM | #6 |
Rock Crawler Join Date: Nov 2008 Location: The Lone Star State
Good start. You need to get a bit more ground clearance to make that thing crawl. The way it sits you'll get high centered a lot.
12-10-2013, 03:31 PM | #7 |
| Re: Axial AX10 Scorpion Rookie build |
12-10-2013, 04:46 PM | #8 |
Pebble Pounder Join Date: Mar 2013 Location: Vancouver
What he means is you run the chance of high centering the center of your chassis on climb overs, thats the challenge to get a lcg but good clearance, ultimately depends on where you run and what works for you. I like it so far and I say run with it |
12-10-2013, 05:03 PM | #9 |
High centered isn't the height of the center. It means hung up on the center skid. If your scx10 shocks aren't limited internally, you'll need to drill some holes in the chassis to raise the chassis a bit. 2-3/4" ride height is a decent start. Roughly aim for your lower links to sit flat, or level. Slightly higher in the rear to help you "break over" obstacles. Some run higher, some lower. It depends on many factors where you end up. |
12-12-2013, 08:44 PM | #10 |
I see what your saying now, I need more height at my center or ill bottom out on rocks. Also, I don't have a very good steering caused by my links hitting the chunk. What's the best solution?
12-12-2013, 09:30 PM | #11 |
Rock Stacker Join Date: Jun 2009 Location: Idaho Falls
Definitely low but depending on the type of terrain you crawl it could work. I would raise it a bit though
12-13-2013, 01:18 AM | #12 |
RCC Addict Join Date: Jun 2009 Location: Salmon Arm BC
looks good man.. for the body you can run anything thats 200mm+.. me and my friends run on road car bodies like the datsun 510, honda civic, vw bug, i ran the parma '34 ford and now run the stock body until i can find something i like.. |
12-13-2013, 09:49 AM | #13 |
Pebble Pounder Join Date: Jul 2012 Location: Crawlerado Springs
Looks good! For sure get that belly up a little and on the skid plate the center most bolt holes can be used to hold the skid to the chassis sides leaving the front and rear most holes as a place to mount the lower control arms on the inside of the chassis sides. Will have to grind the corners off a little on the skid plate to clear a spot for the controls arms. But will for sure stop you from getting hung up as much. A ton of ways to tweak the stock chassis for better performance, just takes some research. Don't forget to spend plenty of time on the rocks testing. =)
12-22-2013, 03:59 PM | #14 |
Just ordered a Wraith chassis to swap all my Ax10 stuff over too, will post pics of swap ASAP
12-30-2013, 03:18 PM | #15 |
Got the Wraith chassis in, gotta get new links and will have it up and running again.
Axial AX10 Scorpion Rookie build - Similar Threads | ||||
Axial AX10 Scorpion build on the cheep!! | Papi32 | Axial AX-10 Scorpion | 18 | 02-23-2014 10:22 AM |
Axial AX10 Scorpion | Reptiles 'n' RC | Newbie General | 1 | 12-24-2012 08:04 AM |
R's Axial AX10 Scorpion Build | CreamLad | Axial AX-10 Scorpion | 1 | 03-08-2008 08:49 PM |
Axial Scorpion AX10 Axle Give-A-Way **Free AX10 Axles*** | Rockpiledriver | Axial AX-10 Scorpion | 297 | 08-27-2007 06:15 AM |
I need help with my AX10 scorpion build | Tuffone | Axial AX-10 Scorpion | 30 | 08-25-2007 02:16 PM |
