12-22-2013, 02:58 PM | #1 |
Rock Stacker Join Date: Dec 2013 Location: Fountain Inn
| Greenhorn SuDu One
I debated whether or not to start this thread but I’ll go ahead to get feedback from the veterans. I bought an Axial AX10 used for a good price and it needs work to get comp ready. Played with it for a couple weeks and now its time to build something. Been searching and reading a lot. Lots of help and info here. Also Chris_the_battery_man has been a huge help with answering many PM’s. I really liked the NCD SuDU One chassis and the product Tomy produces. So I ordered one. It’s one its way from Finland. Also got other parts on the way. I want to finish in the next couple weeks so I can compete with the SCRCC guys on Jan 25. Here’s a pic of the AX10 I bought. Won’t use much of it. Probably just the axle housings and tranny for now. Last edited by Lobie; 12-27-2013 at 08:53 AM. |
12-22-2013, 03:00 PM | #2 |
| Re: Greenhorn SuDu One
Here are the specs of the build. Some items I have received, waiting on some, and some have yet to be ordered. • SuDu One 2.2s Chassis (NCD)…received • NCD Front 4-link plate #1 with optional electronics tray (NCD)…received • NCD Rear 4-link plate #2 (NCD)…received • NCD Delrin lower links (NCD)…received • CF or AL upper links made from raw materials (McMaster Carr)…received • Stock AX10 axle housings…received • Creation Fab premium derlin tubes (Creation Fab) …ordered,waiting on • OD/UD gears…ordered,waiting on • Vanquish Axial Wraith lockouts, C-hubs, knuckles (Vanquish)…received • XR10 front universal axles…ordered,waiting on • XR10 rear short axles…received • Mini BR ESC (Holmes Hobby) • Puller 500 Crawl Crawler motor 13t motor (Holmes Hobby) • HS-7980TH servo • Futaba 4PLS…received • 3s Lipo…received • HR Red Anodized AL Balls (Hot Racing) …received • Traxxas 2660 big bore shocks…received • Traxxas 2742X rod ends…received • Castle Creations BEC 10 amp (Castle Creations)…received • Losi mini t springs LOSB1117 (Losi)…received • Misc aluminum fasteners…received • Lattice Innovations hubs (Lattice Innovations) …ordered,waiting on • CF wheels from NCD • HB Rovers …ordered,waiting on Other future items to consider: - NCD Lightweight tranny for SuDu1 (NCD) - Spring cups for BigBores (JeepnDoug) or BB preload collars (DLux) . Last edited by Lobie; 12-30-2013 at 12:50 PM. |
12-22-2013, 03:02 PM | #3 |
My son and I modified the Big Bore shocks. Milled them down on the dremel and shined them up. Should have weighed them before and after. They seem a bit lighter. Have them setup with pink springs for now. Last edited by Lobie; 12-27-2013 at 08:54 AM. |
12-22-2013, 03:02 PM | #4 |
Quarry Creeper Join Date: Sep 2013 Location: New Zealand
If you don't mind me asking, how much have you spent so far/what's your guestimate on how much it'll add up to? Sounds very cool AND pricey |
12-22-2013, 03:05 PM | #5 | |
| Re: Greenhorn SuDu One Quote:
Keep in mind, I'm starting from scratch including radio. I could have used my old FM Artronics but decided to up to the 2.4ghz. | |
12-22-2013, 03:06 PM | #6 |
WOW. The things I could do if I could afford that Very nice. Subbed Last edited by TrilloThrillo110; 12-22-2013 at 03:06 PM. Reason: Subscibing :) |
12-22-2013, 03:30 PM | #7 |
| Re: Greenhorn SuDu One |
12-22-2013, 03:43 PM | #8 |
RCC Addict Join Date: Oct 2011 Location: British Columbia
A hobby wife...interesting concept. One more item you can add to your list. Contact JeepnDoug for some spring cups for your BigBores or DLux for his BB preload collars. No worries about cups falling off and springs coming loose. |
12-22-2013, 03:53 PM | #9 | |
Thanks | |
12-23-2013, 05:06 PM | #10 |
Received quite a few parts today. Best was the SuDu One chassis came in. Craftsmanship is A1. Vanquish Lockouts, C-Hubs, and Knucles Miscellaneous Axial parts Aluminum balls Should get me going. Traveling tomorrow so probably Wednesday/Thursday I'll work on it. Last edited by Lobie; 12-27-2013 at 08:59 AM. |
12-26-2013, 06:30 PM | #11 |
Had a chance to slip a way to the basement at my brothers. Managed to get the chassis and the links put together. I swapped out the hardware for aluminum stuff. Couldn't fine button heads in 25mm so used regular cap heads. Will look for some and swap out. Waiting on tubes from Chris. Hopefully they'll be in soon so I can mod the axles. Last edited by Lobie; 12-27-2013 at 09:05 AM. |
12-26-2013, 06:32 PM | #12 |
Also set the tranny and motor in to see how it fits. Hopefully I can get a tranny from Tomy at NCD. Not the motor I’m gonna use, just for test fit. Need my axles parts to come in so I can add some width and increase the steering angle. Last edited by Lobie; 12-27-2013 at 03:43 PM. |
12-26-2013, 06:42 PM | #13 |
Do these pics look huge on anyone's screen? Sometimes they are huge on my iPad and if I reload them they go back to normal. Just wondering Tried to resize thru BB code but doesn't work on this board. |
12-26-2013, 07:06 PM | #14 |
Big thanks to Haastnooit, Tomy, ZZR 1100 Racer, Oz Bruiser, and the others for their SuDu One write ups. It has helped a lot.
12-27-2013, 01:26 AM | #15 |
RCC Addict Join Date: Oct 2008 Location: Finland
Yes, the pictures are huge. EDIT: Just refreshed the browser and pics are good! Your build is looking good! Good to hear you and your son are enjoying the build together. |
12-27-2013, 01:34 AM | #16 |
Rock Crawler Join Date: May 2010 Location: Belfield NSW Australia
Looking good so far mate :thumbup: Sent from my GT-I9505 using Tapatalk |
12-27-2013, 03:41 AM | #17 |
Rock Crawler Join Date: Jan 2011 Location: At home
Looking good Lobie |
12-27-2013, 09:08 AM | #18 |
12-27-2013, 01:54 PM | #19 |
Messed around today with a couple things. Trimmed down the BB spring cups where the original spring would seat. Need to clean them up some more. Also added a rear upper link brace. And some spacers for the electronics tray. |
12-28-2013, 03:55 PM | #20 |
Greenhorn SuDu One - Similar Threads | ||||
Alex's SuDu 2.2s. | AlexG | Team Losi Comp Crawler | 70 | 05-20-2014 01:20 PM |
Fester's SuDu | FesterUK | Axial AX-10 Scorpion | 21 | 05-31-2013 09:50 AM |
Harvo's SuDu | Harvo | Axial AX-10 Scorpion | 37 | 05-02-2013 07:22 PM |
Complete greenhorn here need some help with what to do... | beyondink | Newbie General | 12 | 10-03-2008 02:19 PM |
