03-16-2016, 10:33 AM | #1 |
Rock Crawler Join Date: Mar 2016 Location: Murphy
| Front Diff
Just bought a Scorpion the front different doesn't lock like the rear. If you turn one front wheel the other turns the opposite direction. Did these come without the front different locker?
03-16-2016, 11:14 AM | #2 |
Pebble Pounder Join Date: Jan 2016 Location: Athens
| Re: Front Diff
You need to open up your housing something don't sound right yes they are suppose to have lockers in them Sent from my iPhone using Tapatalk |
03-16-2016, 12:10 PM | #3 |
RCC Addict Join Date: Aug 2012 Location: The Garage!!!
| Re: Front Diff
If it is a vertical plate axial chassis(ax10) yes they come locked! Sounds like been swapped with spider gear type setup?
03-16-2016, 07:55 PM | #4 |
| Re: Front Diff
There's so many different versions of the early Scorpions I thought I saw some where that there essential a version that didn't have a front locker. I'll order a set of locker and open it up. Being used I probably need to do that anyway. Thanks for the advice.
03-17-2016, 12:33 AM | #5 |
I wanna be Dave Join Date: Nov 2014 Location: West Texas
| Re: Front Diff
You read correctly, there was or is a version of the scorpion that had an open front diff. If my memory serves me there was a pin you could install to lock it. However the Holmes Hobbies spool will fix you up and remove some of the wheel slop.
Front Diff - Similar Threads | ||||
Front diff.... | twisted | Axial Yeti | 5 | 06-21-2015 03:03 PM |
front diff | vito | Axial Yeti XL | 3 | 05-10-2015 06:45 AM |
front diff? | hende | 1:1 Full Size Vehicles | 3 | 10-22-2012 04:10 PM |
independent front suspension and front diff build | canadian scx10 | Axial SCX-10 | 1 | 02-13-2011 07:52 PM |
front diff | Oze30 | Axial AX-10 Scorpion | 2 | 12-22-2007 02:41 PM |
