Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Capra
Thread: 48 pitch 11 tooth pinion gear?
Old 07-02-2020, 04:22 PM   #1
Question 48 pitch 11 tooth pinion gear?
Hello friends, I want to swap out the stock 14 tooth pinion gear for a 11 tooth pinion gear in my Capra, but try as I might I cannot find one that is 48 pitch. I see that there are plenty of 32 pitch pinion gears available. Can I use a 32 pitch 11 tooth pinion gear in the Capra?
NeoPyro is offline   Reply With Quote
Old 07-02-2020, 04:45 PM   #2
Default Re: 48 pitch 11 tooth pinion gear?
The Capra takes 32 pitch pinion , I have an 11 tooth and it’s perfect imho for my setup.
crazy nick is offline   Reply With Quote
Old 07-02-2020, 05:58 PM   #3
Well if for some reason you do happen to need 48P RRP makes an 11T
https://www.rpphobby.com/product_p/rrp1411.htm
Old 07-02-2020, 07:24 PM   #4
It's 32 pitch? Huh, on page 23 of the online manual it lists AX30569, which is a 48 pitch 14 tooth pinion gear. I'm so confused. Did they switch to 48 pitch gears at some point or vise versa?
Old 07-02-2020, 07:32 PM   #5
I dont have a Capra but looking at parts it does appear to be 48P
EDIT: hmmm I'm confused now too looking at the gear set most are 48P but the spur does look like 32P https://www.amainhobbies.com/axial-c...2/p1049129?r=0
Open it up and check?
Old 07-02-2020, 07:49 PM   #6
This is what I am using
AXI30722
Axial 32P Pinion Gear w/3mm Bore (11T)
swerg is offline   Reply With Quote
Old 07-02-2020, 09:24 PM   #7
Pinion gears aren't that expensive. I'll give a 32 pitch a try and if it doesn't work I'll get the 48 pitch.
Thank you guys for your insight and assistance.
Old 07-03-2020, 03:30 AM   #8
Trust me , it’s 100% 32 pitch
48 pitch 11 tooth pinion gear? - Similar Threads
How many tooth pinion gear for 45T motor? GTSLOW G-Made Crawlers 2 10-04-2015 10:27 AM
Bully pinion gear - what tooth and pitch? Tomy RC4WD Bully 1 04-18-2009 10:17 AM
