02-03-2023, 03:06 PM | #1 |
Newbie Join Date: Dec 2022 Location: US
| Need help with a stripped screw.
Heard some grinding coming from the trans on my capra. Thought I'd take it apart to investigate and stripped the screw. Anyone have any suggestions that won't hurt my motor? Sent from my SM-S908U using Tapatalk |
02-03-2023, 03:47 PM | #2 |
Rock Crawler Join Date: Nov 2014 Location: North to Alaska - go north, the rush is on....
| Re: Need help with a stripped screw.
It takes time for it to set up, but I have used JB weld to attach a cheap allen/hex wrench to the screw head. It does not always work, but has a couple times for me. |
02-03-2023, 03:58 PM | #3 |
Thx. I'll try that or buy an easy out Sent from my SM-S908U using Tapatalk |
02-03-2023, 04:07 PM | #4 |
RCC Addict Join Date: Nov 2017 Location: Austin Texas
Good suggestion ^^^ I've also slotted stripped screw-heads with a thin Dremel cut-off wheel. I even keep some old worn down ( smaller) wheels for just such an occasion. Slot it as best you can then go in with a wide enough flat-head screwdriver to extract it. Also you can sometimes take an allen key ( not a good-quality driver... don't want to ruin those lol) that is one size bigger and 'gently' tap it in there with a hammer to see if it will catch enough to slowly turn it out. If that doesn't work, you can even sometimes take that larger size key and shave it a hair on all sides to get it a bit smaller... then try again to tap it in there to see if it engages enough to rotate the screw outta there. |
02-03-2023, 04:08 PM | #5 |
Did you use loctite? If so you may want to apply some heat with a soldering iron before attempting removal. You could sacrifice a torx bit thats a bit oversized for this fastener, hammer it in and give it a try and hope it doesnt also strip. You could try to grind a slot in it and use a flat head screw driver to remove it. this might be my last resort BTW I stripped a fair number of screws before I got a nice set of hex drivers. Basic/cheap tools often have a loose fit and often lead to stipping heads. Vanquish and MIP make great percision tools. |
02-03-2023, 04:28 PM | #6 | |
| Re: Need help with a stripped screw. Quote:
Sent from my SM-S908U using Tapatalk | |
02-03-2023, 05:19 PM | #7 | |
RCC Addict Join Date: Jan 2019 Location: Corvallis, OR
I would echo this entire post Sent from my iPhone using Tapatalk | |
02-04-2023, 02:37 AM | #8 |
Rock Crawler Join Date: Mar 2019 Location: Terrassa
Heat is your friend when it comes to too much loctite.. |
02-04-2023, 03:47 AM | #9 |
Rock Stacker Join Date: Sep 2011 Location: UK
| Re: Need help with a stripped screw. |
02-04-2023, 09:35 AM | #10 |
Bit of "tin foil" and an old Allen wrench. I have also used the reverse "ez-out" chamfering tool, and it grabs most hardware.
Need help with a stripped screw. - Similar Threads | ||||
Stripped Screw | TheBigRigger122 | Axial Wraith | 7 | 01-14-2016 07:37 PM |
Stripped Hex Screw - Craftsman Screw Extractor | bigstu | Tools, and Procedures | 8 | 11-05-2011 08:48 AM |
Stripped grub screw | Highboost73 | Axial SCX-10 | 3 | 09-15-2010 03:48 PM |
Stripped screw | Tyler Kadlec | General Crawlers | 24 | 10-08-2009 05:22 PM |
stripped screw | eric113 | General Crawlers | 10 | 03-06-2005 04:42 PM |
