04-09-2016, 09:43 PM | #21 |
| Re: Anyone using the Incision SS links?
I ordered a full set of these the other day for a new Wraith build and when I pulled them out of the mailbox I was surprised at how heavy the package was. I was like, "when did I order wheel weights? Oh yeah." They are very nice links though, like mentioned above, typical VP quality. When you work with TI links for so long and you grab one of these they feel like they're mad of lead.
04-09-2016, 10:48 PM | #22 | |
Quarry Creeper Join Date: Dec 2009 Location: Cape Cod
| Re: Anyone using the Incision SS links? Quote:
04-09-2016, 11:11 PM | #23 |
I joined the Band! Join Date: Feb 2015 Location: On a rock
| Re: Anyone using the Incision SS links? |
04-10-2016, 06:27 AM | #24 | |
Newbie Join Date: Apr 2016 Location: Conway
That's what I figured, I just thought it odd that it wouldn't come with the right screw, and that well maybe I was doing something wrong. Thanks. | |
04-10-2016, 08:33 AM | #25 | |
Rock Crawler Join Date: Feb 2010 Location: Central/SE Ohio
04-11-2016, 01:42 AM | #26 |
Newbie Join Date: Dec 2015 Location: Bremerton
Looking at the screw in the picture, it's the correct length SS screw. The drag link just needs to be between the mounts with the other one on top.
04-11-2016, 05:49 AM | #27 |
04-11-2016, 11:11 AM | #28 |
Quarry Creeper Join Date: Nov 2014 Location: WA
it is too short if used with the stock plastic knuckles. I got another longer screw ans is all good. |
04-11-2016, 11:16 AM | #29 |
Pebble Pounder Join Date: Feb 2014 Location: tucson
I'm going to have to take a look at mine. I don't recall having a problem mounting mine and my front end is all stock, except for the incision links.
04-11-2016, 11:39 AM | #30 |
The screw that was sent to me just barely peeks out of the lower plastic arm when the draglink is in the middle. It was odd because the kit itself did not even include a screw. I found a little baggy with one wrapped up inside the invoice from RPP.
04-11-2016, 02:16 PM | #31 |
Newbie Join Date: Jul 2012 Location: Bremerton, WA
That's odd, the one mine came with worked perfect. I would contact Vanquish and mention that the wrong screw was included. I didn't have a problem installing the links. The screw is separate because the ends and balls for the links are Traxxas Revo ends. You can find the part number on their website. I would bet the person packaging the links just grabbed the wrong screw. You can contact Vanquish or source a stainless steel screw locally from a hardware store.
04-14-2016, 01:03 PM | #32 | |
I may get some of the plastic spacers that came with extra parts to fill the blanks... Or try axial ball ends. anyone have any better way to fix it? | |
04-14-2016, 01:58 PM | #33 |
Just a heads up, if you run your Bomber full speed into a metal pole, the SS Drag Link will bend... Luckily it was in a place where I could bend it back. I let me girlfriend's 10 year old son drive it for a few minutes. The plastic end broke so I ran to my LHS and bought the correct Revo end kit and it's what came with my Link Kit so I have spare parts.
04-14-2016, 02:19 PM | #34 |
04-14-2016, 02:29 PM | #35 | |
Everything else I just gave an extra half turn of the screw to pinch in the plastic, there are no problems doing that. It helps drilling out the front hole with a 3mm bit to make everything go together a little easier. | |
08-16-2016, 08:55 AM | #36 |
Newbie Join Date: Sep 2015 Location: uk
Have anyone had any issue with the front steering rod? I havent seen anyone having the same issue as i have. I installed mine but it seems a bit shorter compared with the stock one. here is the stock steering link: VP suggested to loose both road ends: Finally, both wheels are in parallel but I am a bit worry about the strength of both rod ends. it seems that I have to loose 1/3 of the thread to get two front wheels in parallel. Is this normal? Thanks |
08-16-2016, 09:19 AM | #37 |
It's normal from what I've seen from VP links stainless or Ti. They have to accommodate different knuckles and steering arm lengths and you need to be able to adjust toe in and out. If they made them to fit your length perfect they might be too long for another setup and there's not much you can easily do for a tie rod that's too long. Use the supplied M4 rod ends in your parts bag to take up the rest of the threads if you like but I've ran with more threads exposed than yours and never had problems.
08-16-2016, 09:25 AM | #38 |
Newbie Join Date: Aug 2016 Location: San diego
That will make it weaker for sure. I just ordered my set and It should be here tomorrow or Thursday and I hope its the correct length. I will post back when I get it.
08-16-2016, 09:31 AM | #39 |
RCC Addict Join Date: Jul 2009 Location: Ontherocks
Replacement Revo rod ends are cheap. If you are worried, keep a pack of them in your tool box. But I havent had any issues personally.
08-16-2016, 10:40 AM | #40 |
I broke one of the revo ends on the steering when I let the GF's son drive it, at 10 years old he hit the throttle and ran it right into a steel pole on the grill at the park we were at. The SS links held up great to the impact.
Anyone using the Incision SS links? - Similar Threads | ||||
vanquish incision chassis and links help? | perry3182 | Axial AX-10 Scorpion | 4 | 01-21-2010 07:58 AM |
VP Incision chassis links - what length? | Rig Rocker | Axial AX-10 Scorpion | 9 | 12-23-2009 04:56 AM |
VP Incision | Deezul | Axial AX-10 Scorpion | 2 | 12-01-2009 05:44 PM |
